Large Capacity Power Steering Reservoir
I have a question for the minds here related to my BMW H31 hydroboost setup.
I am having an issue where my accumulator will loose its capacity to hold the fluid in reserve and will dump whatever volume of fluid it holds (~ 0.5 qt.?) into the reservoir. I am running the stock PS reservoir and if I am keeping my reservoir at the recommended level, the reservoir will overflow when this charge is dumped resulting in a bunch of fluid on the floor.
This typically occurs after the car has sat for a few days.
I have read that this is likely a failure of the accumulator or the regulator. I have a new accumulator on the way, but regardless, this still presents an issue where in the event of an emergency, I would have a bunch of PS fluid coming out of the reservoir in the middle of a (likely) panicked braking event.
So coming to my question. Does anyone know of a large capacity PS pump reservoir that is available? I have looked around quite a bit, but haven't found anything. I would even settle for an aluminum one that could be modified for the extra capacity, If anyone has any leads or ideas, I'd love to hear them.
87944turbo- Posts : 76
Re: Large Capacity Power Steering Reservoir
I have the BMW HB and IMHO, it's the best system to use for our swaps. A bit complicated, but very reliable and the brakes feel just like before the swap. I have an early car with S2 brakes and suspension. It weights 1230kgs and stops amazing! I used the BMW reservoir, mounted on the same mount that the Porsche reservoir was. I used a Turnone pump on F body mounts. And yes, its on the opposite side of the engine from the reservoir. This was a bit troubling, but caused no problems. I have a 1" tube plumbed behind the waterpump and under the TB from the reservoir to the pump. It's a daily driver for a few summers now, and has worked perfect.
Good luck!
Gord.
Good luck!
Gord.
murrayg- Posts : 105
Thanks for your reply! I would be really interested to see how your line connects to the pump. That reservoir does look quite a bit larger than the stock F-body one. It's really interesting to have it in that location. I would have thought the reservoir would have been too low there. Good to hear that there are good working solutions out there.
I really do like the feel of the BMW hydroboost brakes. Like you said, they are quite complicated. I have a cooler and a filter hiding behind the bumper support, so can certainly understand what your saying. For me especially since I running manual steering, it seems like an awful lot of plumbing with potential for leaks, etc...
The connection to the pump was stressful...but worked out well. It's a new Turn-One pump for this swap, and is a bit expensive. I removed the stock reservoir and threaded the fluid input of the pump to 1/2NPT (IIRC). I was then able to thread in a 1/2NPT to hose nipple and used a 90deg molded rubber hose to connect the tube to the pump nipple. I go to my local NAPA store and just go in back and hunt to find the hoses I need. Often a complex molded hose will yield you quite a few 90's. I have the top of the cap on the reservoir within 1/8" of the hood, and still the bottom is lower than the pump inlet. However, the fluid level in the reservoir is above the pump intake. It makes some wining sounds until the air is out of the system, then all good. I pump the brakes with the engine off until "power brakes" stop (the accumulator is empty), then fill the reservoir to the top.
Funny addition...I also have power steering with the engine off, until the system accumulator empties. Not intentionally, but that's how it works!
Good luck,
Gord.
Good luck,
Gord.
» Newb 944S LS1 Conversion
» how-to- Power steering to Manual Steering conversion...
» Power Steering Cooler
