WTB: TPC LS Swap Kit
EDIT** Kent eventually contacted me, but I had already bought TPC kit from Dirt Rocket (Thanks By the Way!)
Still looking for the following:
TPC Billet F-Body Power Steering Bracket
F-Body Alternator Bracket
TPC Hydroboost Brake Adapter
Let me know what you have. I will edit again if I end up ordering from TPC.
-Kevin
-Kevin
teh_Fawker- Posts : 3
Re: WTB: TPC LS Swap Kit
Here is the list of parts I bought from TPC:
C5 Corvette Bell Housing - New
C5 Bell Housing dust cover
C5 Corvette Bell housing Adapter Plate
Hydraulic Slave Throw Out Bearing
With Hoses, Fittings and Bleeder Valve
TPC Clutch Kit
TPC Clutch, Steel Flywheel, Stock Pressure Plate, ARP Bolts for Flywheel and Pressure Plate
LS Engine Pilot Bearing Adapter
LS Engine Conversion Motor Mount Uprights
Solid Motor Mount Bushings
1/2 Spacers
TPC Turbo Style Radiator
Includes 944 to LS hoses, 187 degree Thermostat, straight lower hose outlet
TPC 944 Turbo Fan shroud kit
Heater Control Valve and Hoses
VSS Kit With Sensor
Custom Oil Pan w/ Internal Baffles
V8 Exhaust Headers from TPC
If you're interested, please call or text me at 570 317 3464, make me an offer and we can work something out.
TPC Clutch Kit
1/2 Spacers
VSS Kit With Sensor
DirtRocket- Posts : 6
Hey OP. I was having the same problem. Call him when you get a chance. They are doing three customer swaps right now and are swamped. Also I just found out they have way more available then what is on the site. Hydro break setup and radiator and a few other things not listed. I just got a hold of Kent Friday. Nice guy. Ordering my parts today.
Eric00433- Posts : 8
There's someone parting out there swap on facebook marketplac. Think he has a bunch of tpc components
porschekid7- Posts : 6
Got a link. I can only see within 100 miles.
Check out my post if you need a TPC LS Swap Kit with a lot of extras.
Zach
Zach
Zach968- Posts : 2
Today at 12:47 am by sharkey
