944 Radiator Grommets (Upper) EmptyYesterday at 11:51 am by geegeesbits@gmail.com
944 Radiator Grommets (Upper) EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
944 Radiator Grommets (Upper) EmptySun Jan 26, 2020 4:51 pm by j7wolfe
944 Radiator Grommets (Upper) EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
944 Radiator Grommets (Upper) EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
944 Radiator Grommets (Upper) EmptySat Jan 18, 2020 7:15 am by Rothaus
944 Radiator Grommets (Upper) EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
944 Radiator Grommets (Upper) EmptyThu Jan 16, 2020 2:11 am by Golten1986
944 Radiator Grommets (Upper) EmptyTue Jan 14, 2020 2:48 pm by Gumby
944 Radiator Grommets (Upper) EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
944 Radiator Grommets (Upper) Empty 944 Radiator Grommets (Upper)
Post  MotoRider42HC on Tue Jul 02, 2019 9:44 am
Does anyone have Radiator Grommets lying around, that they could take measurements of, or at the least send me a couple pictures?
I plan to 3D print replacements out of Polyurethane, and I will freely share the CAD file with everyone.
All I need is measurements and/or pictures of these grommets.
Thanks!
- James
MotoRider42HC
MotoRider42HC
944 Radiator Grommets (Upper) Empty Re: 944 Radiator Grommets (Upper)
Post  Hotrodz of Dallas on Tue Jul 02, 2019 10:22 am
https://www.paragon-products.com/Upper-Radiator-Mount-p/pp-951.106.053.00.htm
Hotrodz of Dallas
Hotrodz of Dallas
Post  MotoRider42HC on Tue Jul 02, 2019 11:07 am
Hotrodz of Dallas wrote:https://www.paragon-products.com/Upper-Radiator-Mount-p/pp-951.106.053.00.htm
Thanks!
If only they had a ruler next to it...
I'm going to 3D-print mine at 1" and hope they work the first try.
MotoRider42HC
MotoRider42HC
Post  Hotrodz of Dallas on Tue Jul 02, 2019 11:12 am
Make them 1", then cut off as needed to get the radiator to just clear the top of the support.
Hotrodz of Dallas
Hotrodz of Dallas
Post  MotoRider42HC on Tue Jul 02, 2019 5:39 pm
As promised, here is the CAD file for "Upper Radiator Mount" for an LS Swap radiator.
https://drive.google.com/open?id=12H1UKYWFYjxExJtcp1a9z_RQLBAQf_2w
Notes:
- you will need TPU filament, which requires a direct-drive extruder
- lay down blue painters tape on your print bed to protect it from the TPU
- pause the print at (7.35)mm height, and insert (2) M6 washers
- pause the print at (8.40)mm height, and insert (1) M5 washer
Feel free to ask questions to:
https://speedfreakengineering.com/category/contact-us/
James
MotoRider42HC
MotoRider42HC
