Moroso Milodon Oil Pan Modification
Im a bit confused. The dimensions in the oil pan mod threads (XSchop) claim an 8.75 by 2.5 inch insert/slotting to the drivers side.
On my conversion, I measured the cut-out to be 5.75 by 2.5 inches.
Im thinking that Robs dimensions are for 944's using a power steering rack and that mine is shorter due to my manual steering rack???? I really dont want to weld in the patch piece just to find out later that it needs to in fact be 8.75 inches long to clear something I havent thought about. Otherwise, I made the cut as seen above and installed the engine and it wass perfect. The drivers side steering rack mount and such fit into the cut I made quite nice and neatly.
So whats the dealy-o?
Info please! Thanks
Info please! Thanks
Re: Moroso Milodon Oil Pan Modification
Anybody? Need to get this thing welded.
Well...
It's not gonna rust...
Patience, Grasshoppa.
First, verify engine uprights and hood clearance MK. (Didn't you say the engine was "forced"? Also, have you trimmed the rack bosses?) It may mean an extra step or two, but if you move the engine with a modification to the uprights, you may have to redo the pan. AND...if the hood doesn't close, well, welcome to "The Hood"...
Let's cover everything...
Transaxle mount? OK? New?
.02, ching, ching.
.02, ching, ching.
gt1scca- Posts : 795
I knew you'd come through.
Grasshoppa? Im a guru damnit.....for both LT and LS (well, not really for LS yet)
Not concerned about the engines placement vertically at this point but just simply, why the 8.75 inch notch? But youre right inthat 'whats the measurement of the notch at forced/relaxed placement.'
I think Rob/other members see or forsee something I dont with this measurement.
Heres MichaelB's pan
EDIT!: Okay...Im stoopid. I think I found the answer. The notch is longer for PS racks! Theres some lines that need to clear! New question is, Do I ever plan on going back to PS?? Nah.
On the side note [nothing to do with this thread but interesting nonetheless]...check out plmwaters crossmember mod!
Yep, saw that back on PHB. I think that was his solution for the spacers?944-LT1 wrote:...check out plmwaters crossmember mod!
Nice welds...
» oil pan options
» Modified Moroso 20140 + Pickup
» Oil Pressuer Sender / Relocation Adapter Modification
