motor mount fail
motor mount fail
Hi all,
The car just dropped the fastener for the left motor mount. It's the mount to cross member end. Before I jack the thing up at lunch (at work), any idea what I need? I think it's a stud, so I need the nut and washer......assuming the stud didn't break. Thread and size, anyone??
Gord.
##- EDIT Just under the car....the stud is broken off flush with the bottom of the motor mount. Any suggestions?? Is this common??
Thanks again,
Gord.
Gord.
Thanks again,
Gord.
murrayg- Posts : 105
Re: motor mount fail
Several different motor mounts on the market, who produced yours?
acorad- Posts : 697
who produced yours?
TPC.
I'll post a picture shortly.....
Does it look like this with the stud in the bottom sheared completely off?
acorad- Posts : 697
yes. I don't have it off yet, but it is like your photo.
It's off now. Exactly like yours. Is there an issue here?? Whats the way forward?
Gord.
Both of my mounts failed, I think they were originally from Renegade in Vegas, although I don't know for sure. In addition to the sheared off stud, the rubber delaminated from the metal on both mounts. Probably from the unexpected forces on them due to the stud shearing off.
Anyway, I replaced them with TPC's new mounts.
You can read about it here: [You must be registered and logged in to see this link.]
Andy
Andy
acorad- Posts : 697
another shot. These aren't Renegade.
Ya, those are the same ones I had that failed. Maybe some previous version from TPC?
Andy
Andy
acorad- Posts : 697
Yes! I had that same failure on one side back in 2014. Eric (he was still running TPC) made me a set of mounts with hardened bolts. But those had the plastic bushings disintegrate. But I mixed and matched, new mounts with old bushings and they're still going strong today.
I had three sets of TPC mounts fail. Broke each revision of them.
