TPC Radiator - How To Install ? (Solved) EmptyYesterday at 11:51 am by geegeesbits@gmail.com
TPC Radiator - How To Install ? (Solved) EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
TPC Radiator - How To Install ? (Solved) EmptySun Jan 26, 2020 4:51 pm by j7wolfe
TPC Radiator - How To Install ? (Solved) EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
TPC Radiator - How To Install ? (Solved) EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
TPC Radiator - How To Install ? (Solved) EmptySat Jan 18, 2020 7:15 am by Rothaus
TPC Radiator - How To Install ? (Solved) EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
TPC Radiator - How To Install ? (Solved) EmptyThu Jan 16, 2020 2:11 am by Golten1986
TPC Radiator - How To Install ? (Solved) EmptyTue Jan 14, 2020 2:48 pm by Gumby
TPC Radiator - How To Install ? (Solved) EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
TPC Radiator - How To Install ? (Solved) Empty TPC Radiator - How To Install ? (Solved)
Post  MotoRider42HC on Mon Jul 01, 2019 12:24 pm
Update: Solved:
The TPC radiator is not a complete kit, and is not a direct-fit upgrade.
We had to take a 3lb hammer to the upper radiator support in multiple places.
Then we had to re-bend the provided brackets.
Then I had to 3D-print new upper radiator grommets ($9ea for OEM ones).
Then I had to go buy a 1/4" NPT fitting for the overflow/reservoir connection.
*And we plan to make another two support brackets to make sure it stays in place.
So, I bought the Radiator Kit from TPC, and there were no instructions included at all.
How am I supposed to mount this thing???
Anyone have pictures of how the radiator is mounted?
Any pictures of how the coolant reservoir is connected to it?
What are these brackets for, and where do they go?
What are these three extra ports for?  Which one goes to the coolant reservoir?
Thanks!
MotoRider42HC
MotoRider42HC
TPC Radiator - How To Install ? (Solved) Empty Re: TPC Radiator - How To Install ? (Solved)
Post  MotoRider42HC on Mon Jul 01, 2019 8:17 pm
We managed to get the radiator into the car, but now we don't even think the radiator will fit at all...
Someone with the TPC radiator kit, please please please help us!!!
MotoRider42HC
MotoRider42HC
Post  MotoRider42HC on Mon Jul 01, 2019 8:18 pm
and two more pictures
MotoRider42HC
MotoRider42HC
Post  Hotrodz of Dallas on Tue Jul 02, 2019 7:58 am
MotoRider42HC wrote:So, I bought the Radiator Kit from TPC, and there were no instructions included at all.
Thanks!
The 2 aluminum brackets go on top of the radiator for the original bolts and grommets to set on. The large port on the top left corner of the radiator was meant for the Porsche fan switch, but the rad manufacturer screwed up on the thread size. So just leave the aluminum plug in. The small port above it is where the coolant bleed hose goes that attaches to the coolant reservoir. The coolant crossover pipe under the intake will tee into the hose that goes to the reservoir as well.
Hotrodz of Dallas
Hotrodz of Dallas
Post  MotoRider42HC on Tue Jul 02, 2019 9:30 am
Something is definetely wrong, then. Those aluminum brackets are way too wide for the radiator he sent me, there is no way they'd hold it in place. Even worse, this is a 30-year-old car, but he expects us to use OEM rubber grommets? Really? He didn't bother to mention that, so those went to the dump three months ago along with the OEM radiator. I still have the radiator mounting bolts, but thats it.
He also did not include a fitting for hooking-up the coolant resevoir. Am i expected to know what size fitting to buy? AN? NPT? ???
I'll go get more pictures and post here soon.
MotoRider42HC
MotoRider42HC
Post  MotoRider42HC on Tue Jul 02, 2019 11:02 am
(click on picture to see it)
the picture below shows that the brackets provided are almost 1/2" too wide
they do not fit at all
does anyone have pictures of the TPC radiator installed in their vehicle?
MotoRider42HC
MotoRider42HC
Post  sharkey on Tue Jul 02, 2019 2:10 pm
im not sure if your aware but the turbo radiator was 1" taller than the n/a, s and s2 rad, and the height difference was accounted for with a different lower rad support. im not sure but looking at the pics it looks like this rad is designed to replace a turbo rad and use a turbo lower rad support.
Post  MotoRider42HC on Tue Jul 02, 2019 3:13 pm
This TPC radiator kit came with a custom lower radiator support. There is about 1/2" to 1" mistake somewhere that is preventing me from installing the radiator.
MotoRider42HC
MotoRider42HC
Post  matt889 on Fri Jul 05, 2019 10:36 pm
the stock coolant thermo switch doesnt screw into the rad ??!~??!?!?
matt889
Post  murrayg on Sat Jul 06, 2019 4:43 am
sharkey wrote:turbo radiator was 1" taller than the n/a, s and s2 rad,
Clarification - the Turbo and S2 rad are the same taller size. As you said, they are about 1" taller than the NA rad.
murrayg
