» Early 944 Fuel Line Routing
Mounts for Aerocatch Latches EmptySat Feb 15, 2020 4:35 pm by rallen130
Mounts for Aerocatch Latches EmptyFri Feb 14, 2020 8:37 pm by VWTortuga336
» 1984 Porsche 944 with 1995 LT1 motor for sale
Mounts for Aerocatch Latches EmptyThu Feb 13, 2020 12:47 am by jerry944
» Wizard Cooling Radiators!!
Mounts for Aerocatch Latches EmptyWed Feb 12, 2020 12:32 pm by 87944turbo
» Oil and Cooling question
Mounts for Aerocatch Latches EmptyWed Feb 12, 2020 6:01 am by gwistrup
» V8 Conversion Parts
Mounts for Aerocatch Latches EmptyTue Feb 11, 2020 10:49 am by Chevota350
» Coil mounting pictures
Mounts for Aerocatch Latches EmptyMon Feb 10, 2020 5:50 am by gwistrup
» 82 924 with AUX Audi V8.
Mounts for Aerocatch Latches EmptyFri Feb 07, 2020 11:40 pm by Golten1986
» 14 Pin Connector - Check Please
Mounts for Aerocatch Latches EmptyFri Feb 07, 2020 9:50 am by Hotrodz of Dallas
» 968 Swap Wiring Checklist/Questions
Mounts for Aerocatch Latches EmptyWed Feb 05, 2020 2:39 pm by Kiltacular Jim
February 2020
3456789
10111213141516
17181920212223
242526272829
Mounts for Aerocatch Latches Empty Mounts for Aerocatch Latches
Post  rdanford on Thu Apr 18, 2019 3:03 pm
Building these for my aerocatch latches....what is the bolt size holding theses down?
rdanford
rdanford
Mounts for Aerocatch Latches Empty Re: Mounts for Aerocatch Latches
Post  87944turbo on Fri Apr 19, 2019 6:12 am
I just did this last weekend. The threads on the pins that came in my kit were M10 x 1.5. I used threaded rod and connected it to the provided pins with these.
87944turbo
Post  rdanford on Fri Apr 19, 2019 12:23 pm
Thanks, actually trying to find the bolt size that is on the frame rails.
rdanford
rdanford
Post  87944turbo on Sat Apr 20, 2019 6:02 am
Oh gotcha, those are just your run of the mill M6 x 1.0.
87944turbo
