» Heat stuck on high
Replacing Rear Rotors  EmptyYesterday at 2:11 am by Porsche951toLS3
» Selling TPC LS Swap Kit + Ceramic Headers + SPEC Clutch / Flywheel + Hydroboost + More
Replacing Rear Rotors  EmptyFri Jul 19, 2019 11:42 pm by matt889
» WTB: TPC LS Swap Kit
Replacing Rear Rotors  EmptyFri Jul 19, 2019 11:24 pm by Zach968
Replacing Rear Rotors  EmptyWed Jul 17, 2019 10:02 pm by sharkey
» Hydroboost low pressure port
Replacing Rear Rotors  EmptyWed Jul 17, 2019 3:03 pm by rdanford
» Alfa Romeo 2.5L V6 --> '78 924
Replacing Rear Rotors  EmptyMon Jul 15, 2019 5:11 pm by porschekid7
» WTB: LS Swapped 944
Replacing Rear Rotors  EmptyMon Jul 15, 2019 4:57 pm by porschekid7
» 1987 Porsche 944 S - Transaxle FOR SALE
Replacing Rear Rotors  EmptySun Jul 14, 2019 12:55 pm by MotoRider42HC
» V8 Swap Project Car Swap Out
Replacing Rear Rotors  EmptySun Jul 14, 2019 6:12 am by DirtRocket
» Transaxle rebuild
Replacing Rear Rotors  EmptyFri Jul 12, 2019 8:12 pm by Jasonscottw
July 2019
Replacing Rear Rotors  Empty Replacing Rear Rotors
Post  mred2nice on Sun Mar 31, 2019 12:37 pm
Hello Everyone
Hopefully you can help. I am trying to replace the rear rotors on my 1983 944. I have the caliper off and I am unable to pull the rotor off. I saw a vid about sticking a screwdriver thru a hole in the rotor to relieve the drag that may be created by the parking brake. Unfortunately, I do not have that hole in my rotor. But, each side turns so perhaps it is not the parking brake. I have tried using a weighted hard plastic hammer to try hitting the rotor to free it but nothing.
What am I missing here? Is there something special I need to do to get the rear rotors off?
Ed
mred2nice
Replacing Rear Rotors  Empty Re: Replacing Rear Rotors
Post  kevin924kevin on Mon Apr 01, 2019 10:23 am
have you taken the 2 screws out that hold the rotor on?
Post  mred2nice on Mon Apr 01, 2019 11:00 am
Yes
mred2nice
Post  kevin924kevin on Mon Apr 01, 2019 11:37 am
rotors have a way of rusting to the hub. Make sure ebarake is loose as that can be a pain to loosen off then just work at it.
Post  Rich L. on Mon Apr 01, 2019 10:37 pm
Yup, release that e-brake! I can't tell you how long I banged on my rotors before figuring it out.
Post  mred2nice on Thu Apr 18, 2019 10:13 pm
I finally got them off. Had to use the jacking hole bolt thing. The ebrake is frozen though. While it is apart I am gonna see about getting replacement parts and cables.
mred2nice
