Gasketing for transmission reinforcement plate
Hello,
I'm working on my transmission while it's out of the car, which includes a 5th gear swap and transmission reinforcement plate. I've already got all the parts, and had the tail shaft housing machined down.
The stock tail shaft housing uses a paper gasket. Do I need to put a new gasket on both sides of the reinforcement plate? Just on one side or the other of the plate, or just RTV it both sides and don't worry about the paper gasket?
As much fun as pulling the trans is, I'd really like for it to not leak when it's all buttoned back up!
Thanks!
-Gareth
Thanks!
-Gareth
GarethW- Posts : 26
Re: Gasketing for transmission reinforcement plate
well it depends on how you had the machining done. if they machined the exact thickness of the plate off the rear housing, use a gasket on one side and silicone on the other side. it does not matter what side of the plate the gasket is on. if they machined the thickness of the plate and a gasket off the rear housing, use 2 gaskets.
dont use silicone on the gasket though, thats just a recipe for a leak.
sharkey- Posts : 713
Thanks for the reply Sharkey!
I took the reinforcement plate with me to the shop and had them remove the exact thickness.
Since you have to remove the shift fork to get the reinforcement plate on, I'll silicone the plate to the transmission, and gasket the tail shaft housing side.
Thanks again,
-Gareth
Thanks again,
-Gareth
GarethW- Posts : 26
i myself do it the other way, gasket on the trans first, reinforcement plate, then assemble 5th gear, silicone the rear housing and drop it on.
Today at 9:56 am by ndog52
