Defective Manifolds? Polishing Beads Stuck In Them! (Solved)
+2
MotoRider42HC
6 posters
I kept finding these little ceramic beads rolling around my shop floor, and for the life of me i couldn't find where they were coming from. I was scared to death someone at the engine shop stuff them into my engine because they hated their job or some $#**.
BUT THEN
I found out they were lodged inside my TPC manifolds, and randomly falling out whenever I banged on the engine.
Some of these are pretty much stuck forever, but I am afraid that a lot of them will fall out during driving, and possibly damage my Catalytic converter or just bounce around inside my muffler and make tons of noise.
ANY SUGGESTIONS!?!?!!?!?!?!?
Update: Solved:
I beat the $#** out of the manifolds with a Rubber Mallet. And all but (5) of the beads fell out. I talked directly with TPC and they said they'd talk to the manufacturer about this design flaw.
I'm hoping once the engine heats-up, the pipes will expand, and the rest of the beads will fall out. I'll just have to run open headers for a few days, haha.
BUT THEN
Update: Solved:
MotoRider42HC- Posts : 114
Re: Defective Manifolds? Polishing Beads Stuck In Them! (Solved)
Whoa, that's really weird. Did you have your headers ceramic coated? Is a bead form how the ceramic stuff starts out? Dunno Man, I would want to get those out of there too. My long tubes are from TPC, ceramic coated but didn't have those beads in them... at least that I noticed...
Yeah, they were ceramic coated. I have to take the headers off anyway, to get the spark plugs out, so i'm going to beat on them with a rubber mallet and try to get the beads out. If they don't come out, i'm going to try and return them to TPC. Can't have those beads messing-up my cat or muffler.
P.S. Do you like the long-tubes? Have any pictures underneath the car? Since i'm offroading, i have to be super careful with how low the exhaust hangs.
MotoRider42HC wrote:P.S. Do you like the long-tubes? Have any pictures underneath the car? Since i'm offroading, i have to be super careful with how low the exhaust hangs.
The bottom of the long tubes are at the same level as the bottom of the oil pan, so if you're hitting the headers on the ground you're hitting the pan.
chrenan- Posts : 203
Update:
I took the manifolds off and beat the living $#** out of them with a rubber mallet. All but (5) polishing beads are left in them.
My plan is to start the engine with "open headers" and let them rattle out on their own.
Then put my exhaust on.
LOL!
Such a pain, haha.
LOL!
Such a pain, haha.
I’m glad someone else did theirs without a lift. Makes me feel better about what I am about to put myself through. What parts did you order from TPC? I am not sure I really need everything in the kits. What is your thoughts on this?
Sent from Topic'it App
Eric00433- Posts : 8
I'm glad i bought the Deluxe kit... because even with it, there was still so much $#** to buy. LOL
I bought the deluxe kit as well, you still need to buy a ton of other little bits and pieces.
Yea I am gathering parts now but doing it manually instead of kit as I won’t need the speed sensor, throttle wire as mine is drive by wire and I want the long tube headers instead of the shorty. What other little items outside of the deluxe package should I plan for. Already went full suspension upgrade, wilwood 4 piston calipers and slotted and drilled rotors for safety. Bought a rebuilt turbo s trans as well for lsd and cooler. What little parts are you guys seeing from your swaps that I should probably prepare for? I appreciate the help.
Update: Solved:
the beads wont just melt at temperature the Exhaust runs ?
matt889- Posts : 214
They're ceramic polishing beads.
Harbor Freight (or similar) sells surgical forceps that can probably reach down in there and let you grab the remaining stuck ones and yank them out.
sparkydog- Posts : 96
You are a god! I will try!!!
Today at 12:47 am by sharkey
