How To Fit Manual Brakes, Engine In The Way!
Re: How To Fit Manual Brakes, Engine In The Way!
are you using the subframe spacers?
no matter what you do you will have to move the coils. that being said, i cant say ive seen that setup you have used in a v8 swap. any setup ive seen uses a tilton or wilwood bracket that stack the masters vertically. here is what my setup look like
most people dont angle the bracket towards the strut tower, but i wanted the extra room. if you look around here you will find some other setups people have built.
Sharkey,
Is your setup custom-made, or can i buy it somewhere? Part numbers, etc?
(( i wonder if i am trying to install the Kokeln bracket in the wrong direction??? ))
Edit: yes i have the 1/2 spacers installed. i almost forgot them, lol, but caught it at last minute
Thanks!!!
Thanks!!!
MotoRider42HC- Posts : 114
my setup is custom made using a wilwood universal dual master cylinder bracket.
the kokeln dual master cylinder setup was never built with a v8 swap in mind. you are trying to install it correctly.
this one?
https://troyerracecars.com/products/574/wilwood-dual-master-cylinder-mount/?c=asphalt%2Fbrakes%2Fwilwood
do you think something like this might work, too?
https://www.speedwaymotors.com/Wilwood-Forward-Swing-Dual-Master-Cylinder-Brake-Pedal,1960.html
i'd like to do as little Fab work as possible, since i'll have to outsource to a local custom shop. i currently can't mill, lathe or weld. someday... someday...
thanks again for your help!!!
yea the first one is what i used.
it was pretty simple for me to make. started with a 3/16" thick steel plate to bolt to the firewall. i then used some 1" square tubing to build a piece to weld to it and support the master cylinder bracket. add a gusset, built a pushrod using a heim joint and some steel tubing, nothing too hard.
one member here did make a small batch years ago of a mount that was very similar, and there was one for sale in the classifieds not too long ago. maybe have a look and see if its still there.
You are awesome!!! These pictures are perfect! I should be able to have a local shop fab that up, for hopefully not too much. Thanks!!!!!!!!
Is it close if you rotate the Kokeln unit 90 degrees from the orientation in your first pic?
87944turbo- Posts : 76
87944turbo wrote:Is it close if you rotate the Kokeln unit 90 degrees from the orientation in your first pic?
It doesn't fit, that way, either... :'(
rab6594 likes this post
WOW! That is legit!
I definetely need to make the same upgrade, some day. Haha.
