Wilwood front and rear calipers
Has anyone used the wildwood front and rear calipers on their car?
JW1970- Posts : 35
Re: Wilwood front and rear calipers
NA or turbo?
I have seen many NA cars with the wilwoods
Sent from Topic'it App
I have 85.5 turbo setup with the brembos
I hear the wilwoods are good
You may try "rennlist"
Big board on this topic
Thanks for the info, I will look that way!
JW1970- Posts : 35
Got mine from here. They are great.
https://www.wagenswest.com/product/porsche-944-wilwood-caliper-kit-front-rear/
Eric00433- Posts : 8
Ordie792002 likes this post
How much better would you say they are? Are they worth the $975?
JW1970- Posts : 35
Depends on what you are looking for. If you try to find on other sites just for fronts are 800. If you switch to big reds you are looking at $2000 plus turbo spindles and parts. As for braking, only problem I find is too much rear breaking for track or even DD use. Will need a balance bar or something to show more front bias. However there is plenty breaking power for sure.
Thanks for the info! Definitely helps in the decision process.
JW1970- Posts : 35
Has anyone tried these with the Tandem Wilwood MC?
j7wolfe- Posts : 7
» Brembo Front Brakes, From my 968
» Jaguar front calipers
» 83 944 Front Brake Calipers Left and Right different?
