Fuel tank over pressurizing
I have a European spec 944 with an LS1 and am having fuel tank over pressure issues. During the hot months in Houston the tank gets so pressurized that it causes the fuel pump to whine.
Has anyone else on this forum had these issues? Looking for a solution to resolve this.
JW1970- Posts : 35
Re: Fuel tank over pressurizing
are you venting the fuel tank ? like a Evap system ou fuel vapors ?
matt889- Posts : 214
I'm not. I have the original fuel lines running to a fuel regulator. Does the European version have a charcoal canister in the drivers side wheel well? I have read that clogged canisters can cause this issue as well.
JW1970- Posts : 35
Today at 9:56 am by ndog52
