Today at 6:52 pm by chrenan
Today at 5:45 pm by AMFCSL
» Tpc LS adapter plate
Today at 5:41 pm by jimbag
» Headers, headers, HEADERS!
» Electric brakes
Different types of 944 wheels
Post  cfgioja on Sat Nov 28, 2009 6:52 pm
I am not sure what styles of rims came out for 944.
I have been looking online but the biggest ones are turbo twist and cookie cutters. I am just curious, i am running the black 15" rims.
Last edited by cfgioja on Sat Nov 28, 2009 6:53 pm; edited 1 time in total (Reason for editing : Had to double check the image link)
Re: Different types of 944 wheels
Post  modenas on Sat Nov 28, 2009 7:43 pm
19 in rear and 18 in fronts, biggest you can go
modenas
Post  adam7e on Fri Apr 30, 2010 12:55 pm
I've decided on those Miro 371's post swap. I've found them pictured on a 944, and they say they'll hook you up with everything you need for 87 and up. Here I am again, stuck with an 86NA. Damnit. I'd prob source the wheels themselves myself and buy or make adapters, I'm just all freaked out about brakes and fitment issues w/those on the car to even begin worrying about what kind of wheels will fit. Regardless I think these are the sickest non OEM wheels I've seen on these cars..
If you scroll down to the 371 you can see them offered as a kit here:
adam7e
Post  Porch on Sat May 01, 2010 12:50 am
I don't remember what year of car you ended up with, but i think factory Porsche wheels are the best combination of price, quality, weight, and looks.
I've found a bunch of nice looking aftermarket wheels, but unless you spend a couple grand on the wheels alone, they're heavy and made in China.
Post  kelleysj on Sat May 01, 2010 1:51 am
I like the 18" BBS RS-GT thats what im saving for at the moment expensive but i do like the looks of them.[You must be registered and logged in to see this image.][/url[url=http://www.servimg.com/image_preview.php?i=6&u=15163029][You must be registered and logged in to see this image.]
kelleysj
Different types of 944 wheels?
Post  Guest on Sun May 02, 2010 12:31 pm
18 in. in the fronts and 19. in the rear.
Guest
Guest
Post  Guest on Sun May 02, 2010 12:32 pm
Oops, sorry didn't read the above post.
Guest
Guest
Post  Luke714 on Sun May 02, 2010 1:35 pm
I don't think that going to the biggest rim possible is necessarily a good idea. With this much power a little sidewall is a good thing. The only reason to go that big would to be able to find wheels wide enough. Most custom stuff is a couple of grand or you could get factory Porsche wheels but I wasn't able to find 17" Porsche wheels wide enough. Actually, ZR1 replicas seem like a decent option, they are 17" which is good, they are 9.5" and 11" wide which is perfect, they're only $125 each on discount tire, and they only weigh #27 rear, 25.5# font, which isn't epic but isn't that bad either. It'll get enough rubber on until you can afford some CCW's or something. You'll just have to use some mild spacers/adapters. Thanks to xschop for suggesting the ZR1's
Luke714
