tips on removing headers?
i am taking my headers out to have v-bands installed and can NOT get them out of the car!!! right now am struggling with drivers side and cant figure out how to get them out of the car with the engine in the car. Any tips from someone who has done this?
expuppy- Posts : 56
Re: tips on removing headers?
I’m sure that you’ve already tried - and I’m not sure if this will help- but years ago, I had the same problem, drivers side - in the end the header could only go IN from the top side, near vertical, with ports pointed fender side; then counter clockwise turning (viewed from the top). Not sure if relevant for your headers - hope that helps.
Worryless- Posts : 13
If yours are long tube headers, then you will probably have to support the engine and lower the crossmember a few inches.
Today at 12:47 am by sharkey
