Oil Pressure
Oil Pressure
Hello all..just a quick question...
What Oil pressure reading are you getting.
I'm using a stock sensor with an adapter and getting around 50 with initial startup and about 30-35 when hot.(been running for a while)
Pressure still building with pedal press.
Red944ls1- Posts : 98
Re: Oil Pressure
Typically idle cold is about 35-40 psi. Idle hot will drop down to the 20's, and revved up should be around 60 psi. Unless you have an aftermarket oil pump, then the numbers will be 10-20 psi higher.
Re: Oil Pressure
Awesome...thanks. I was not sure if the numbers were in line with where they should be.
Re: Oil Pressure
I have zero when cranking
I think the oil tube oil ring is broke or something
Sent from Topic'it App
Re: Oil Pressure
I got a new I O ring for the pickup tube
Has anyone had issue with the adaptor for the oil filter not sealing or causing no pressure?
Re: Oil Pressure
no issues with the Oil block Orings . Are u running a oil block or a cooler relocate ? was the engine took apart ? did u use the TPC pan and Pickuptube ?
matt889- Posts : 214
Re: Oil Pressure
Pulled the pan
O ring ok
Adaptor o rings look ok
What gives?
Bad front pump??
O ring ok
What gives?
Bad front pump??
Re: Oil Pressure
do you have a mecanical gauge ? im using stock 944 sending unit with a Adaptor off ebay. While cranking no engine running you should get around 2 bars build up while cranking ! tell us the story of ur car and when it started this no Oil pressure. Is it knocking ? or just lifter noise ?
Re: Oil Pressure
It is a junk yard special but the yard guaranteed itvwiuld run
Re: Oil Pressure
When I first got mine together I had to prime the oil pump. It had zero pressure until then. On driver side front there is a hex bit you will unscrew and fill.until it pours our.
Mine was great afterwards.
Re: Oil Pressure
i did take my whole junk yard engine apart so i wasnt worried loll even inspected oil pump and all lol. overkill. i cranked my engine till i say oilpressure on my gauge then started it .
» Help with pressure plate (SPEC pressure plate doesnt fit!!)
» VARIABLE SPEED vs FIXED
» Oil Pressure Sending Unit
