» 1986 951 LS1 swap for sale
Ls3 drive by wire pedal EmptyYesterday at 7:39 pm by turbobob924
» 944 N/A Transmission
Ls3 drive by wire pedal EmptyYesterday at 11:50 am by sharkey
» FS: 88-89 Porsche 944 Turbo S LSD transmission code AOR w/ Cooler
Ls3 drive by wire pedal EmptyThu Aug 15, 2019 9:56 pm by Worryless
» What size oil cooler do I need?
Ls3 drive by wire pedal EmptyThu Aug 15, 2019 6:11 am by gwistrup
» LM7 C5 transaxle
Ls3 drive by wire pedal EmptySun Aug 11, 2019 11:26 pm by TCook
» 5.3 in 1988 with C5 Trans Questions
Ls3 drive by wire pedal EmptySat Aug 10, 2019 6:32 pm by sharkey
» Anyone who’s successfully put a C5 Torque tube in late 944
Ls3 drive by wire pedal EmptySat Aug 10, 2019 2:50 pm by Vortec88Porsche
Ls3 drive by wire pedal EmptySat Aug 10, 2019 2:39 pm by Vortec88Porsche
» A/C Question - WOT Switch?
Ls3 drive by wire pedal EmptyWed Aug 07, 2019 9:28 pm by superman22x
» V8 Swap Project Car Swap Out
Ls3 drive by wire pedal EmptyWed Aug 07, 2019 5:35 pm by DirtRocket
August 2019
Ls3 drive by wire pedal Empty Ls3 drive by wire pedal
Post  Plucky948 on Sat Feb 02, 2019 9:55 pm
Posting to find out if anyone using the GM drive by wire pedal was able to find one that mounts to the floor like stock 944 turbo pedal. I'm not happy with the hanging pedal for driving, it feels like a Camry. It seems using the Jegs Lokar aluminum assembly is better quality. What I really want is the original 944 turbo gas pedal with my rennsport aluminum plate hooked to the GM drive by wire unit on the back. Has anyone done this or something better other than a floor mount box?
Plucky948
Plucky948
Ls3 drive by wire pedal Empty Re: Ls3 drive by wire pedal
Post  Hotrodz of Dallas on Mon Feb 04, 2019 2:40 pm
Plucky948 wrote:Posting to find out if anyone using the GM drive by wire pedal was able to find one that mounts to the floor like stock 944 turbo pedal. I'm not happy with the hanging pedal for driving, it feels like a Camry. It seems using the Jegs Lokar aluminum assembly is better quality. What I really want is the original 944 turbo gas pedal with my rennsport aluminum plate hooked to the GM drive by wire unit on the back. Has anyone done this or something better other than a floor mount box?
I have seen pics of one that used the 944 pedal mounted on the floor with the gm pedal mounted in such a way that the rod was against the back of the 944 pedal. GM pedal was mounted above it to the firewall area. And the plastic gm foot pad had been removed.
Hotrodz of Dallas
Hotrodz of Dallas
Post  Plucky948 on Mon Feb 04, 2019 5:49 pm
That's exactly what I am interested in doing. I did some measurements and as an upgrade the Ferrari 348 solid aluminum pedal would be the best option. It has a longer and thinner footprint and look nice. They perform well though some adjustment would be necessary beyond how to hook the GM pot and rod on the back.
Plucky948
Plucky948
