» 1986 951 LS1 swap for sale
Throw out bearing leak EmptyYesterday at 7:39 pm by turbobob924
» 944 N/A Transmission
Throw out bearing leak EmptyYesterday at 11:50 am by sharkey
» FS: 88-89 Porsche 944 Turbo S LSD transmission code AOR w/ Cooler
Throw out bearing leak EmptyThu Aug 15, 2019 9:56 pm by Worryless
» What size oil cooler do I need?
Throw out bearing leak EmptyThu Aug 15, 2019 6:11 am by gwistrup
» LM7 C5 transaxle
Throw out bearing leak EmptySun Aug 11, 2019 11:26 pm by TCook
» 5.3 in 1988 with C5 Trans Questions
Throw out bearing leak EmptySat Aug 10, 2019 6:32 pm by sharkey
» Anyone who’s successfully put a C5 Torque tube in late 944
Throw out bearing leak EmptySat Aug 10, 2019 2:50 pm by Vortec88Porsche
Throw out bearing leak EmptySat Aug 10, 2019 2:39 pm by Vortec88Porsche
» A/C Question - WOT Switch?
Throw out bearing leak EmptyWed Aug 07, 2019 9:28 pm by superman22x
» V8 Swap Project Car Swap Out
Throw out bearing leak EmptyWed Aug 07, 2019 5:35 pm by DirtRocket
August 2019
Throw out bearing leak Empty Throw out bearing leak
Post  Coloberg on Wed Jan 23, 2019 5:08 pm
Hi all- while trying to bleed the clutch, I noticed after closing the bleeder valve that the black plastic 2 piece that sits atop the release spring was popping apart and the next press of the clutch caused a leak from the seal around the metal tube. Anyone have any issues with this or any suggestions. I talked to Kent and he thought is sounded like a factory failure and was planning to send out a new one. But if you guys have some knowledge to impart- I welcome it. Thanks- mike Throw out bearing leak 55589110
Coloberg
Throw out bearing leak Empty Re: Throw out bearing leak
Post  spence on Wed Jan 23, 2019 5:51 pm
Is the rest of the clutch installed? If not your going to push that cylinder so far it will start to leak.
Post  Coloberg on Wed Jan 23, 2019 6:00 pm
The throw out bearing and bellhousing that are out the othe car. I read that it is easier to bleed outside the car prior to engine install. Should bleeding be done after engine is bolted up in place only? I get about an 1/8 of an inch of travel before the plastic tabs pop off on one side and then it begins leaking. Any advice is helpful. Thanks!
Coloberg
Post  spence on Wed Jan 23, 2019 6:19 pm
If it starts to leak after 1/8" of travel, I'd say its pooched. I thought you might be over extending it and blowing the seal.
Post  sharkey on Wed Jan 23, 2019 8:49 pm
when its sitting as pictured the cylinder is at the end of its travel, if you put any hydraulic pressure to it the retainer will come off and you overtravel the cylinder, and the end result is its junk. the bearing is pushed in when its all bolted to the engine.
Post  Coloberg on Thu Jan 24, 2019 9:08 am
That sadly makes sense. Can I assume that the bleeding should be done installed in the car which would avoid the over extension issue??? Chalk one more up in the live and learn column. Thank you for the insights!
Coloberg
Post  spence on Thu Jan 24, 2019 9:13 am
You could probably bleed it by hand by pulling the bearing in and out. Using the clutch pedal though would cause the bearing to over travel and blow the seal.
