BMW Hyrdoboost Questions
Page 2 of 2
Page 2 of 2 • 1, 2
Re: BMW Hyrdoboost Questions
I'm not sure if it's even that important to have a reservoir big enough to hold all the fluid. I know the mustang HB holds more fluid than the reservoir does. It also has an accumulator, but it's built into the HB itself instead of a separate bomb. There are plenty of of larger reservoirs available though that could be remote mounted to handle all of the fluid in the system.
Thank you. I think at this point fill system and adjust as needed.
kevin924kevin- Posts : 927
Sounds like you're bumping up against a lot of the same things I did. I like that PSC unit, but as has been said, the primary disadvantage is that it would have to mounted higher than the pump. The other option I was looking at was swapping places between the PS pump and the alternator. I think there are some kits out there, but I haven't researched it to heavily.
FWIW, this is my current setup.
One nice feature of the stock reservoir is the cap. I think it's designed to relieve pressure above ~ 6psi. Which is pretty nice. I am not sure, but I don't think the PSC cap allows for pressure relief. Maybe it can or one can be fitted to it?
87944turbo- Posts : 76
looks clean. Thanks for the pics. What size are the lines for the HB
Most of the alternator relocation kits move the alternator forward quite a bit. 944's don't have the room for that at all. They barely have room for the f-body mounts as it is. I know one company that moves the alternator to the spot where the ac compressor goes now. But, if you are building a street car you probably want ac.
Page 2 of 2 • 1, 2
Page 2 of 2
