944 LS1, getting started
i have an 87' 944, i have my motor and im about ready to get started, just a few questions, the brake booster and the steering rack both look like they will be in the way, do i need to remove and replace them, leave them on, or Modify/change them to something else? thanks in advance.
Nik still- Posts : 10
Re: 944 LS1, getting started
The stock brake booster won't fit with an LS, you need to use a different solution for boosting (Ford or BMW hydroboost) or go with manual brakes.
The stock steering rack will fit, if it's a power steering rack you may need to pursuade some of the hard fluid lines on the rack. If it's a manual rack no adjustments needed.
chrenan- Posts : 203
chrenan wrote:The stock brake booster won't fit with an LS, you need to use a different solution for boosting (Ford or BMW hydroboost) or go with manual brakes.
thank you for the information!
Today at 9:56 am by ndog52
