» SBC conversion without hood scoop
Early / late suspension EmptyThu May 16, 2019 1:46 pm by sharkey
» ABS brakes won’t bleed
Early / late suspension EmptyWed May 15, 2019 7:04 pm by knucklehead12
Early / late suspension EmptySat May 11, 2019 10:55 am by Rich L.
Early / late suspension EmptyWed May 08, 2019 3:15 pm by lamrith
» Will this throw out bearing work?
Early / late suspension EmptyWed May 08, 2019 2:48 pm by Admin
» LS Truck engines
Early / late suspension EmptyWed May 08, 2019 1:42 pm by Admin
» Did anyone do a before and after weight?
Early / late suspension EmptyWed May 08, 2019 9:12 am by chrenan
» LF: completed kit or mostly complete
Early / late suspension EmptyMon May 06, 2019 12:36 pm by gamman
» Tuner in Houston
Early / late suspension EmptyThu May 02, 2019 3:25 pm by JW1970
» k & N filter and intake boot
Early / late suspension EmptyTue Apr 30, 2019 8:08 pm by JW1970
May 2019
6789101112
13141516171819
20212223242526
2728293031
Early / late suspension Empty Early / late suspension
Post  Guitmn on Fri Oct 12, 2018 9:01 pm
I'm new here trying to learn the forum and I need a little help: I have an early body (11/84)with no suspension due to a vw project, and have found a donor car that is later model (87). Will the later suspension bolt to the early car?[You must be registered and logged in to see this image.]
Guitmn
Early / late suspension Empty Re: Early / late suspension
Post  sharkey on Fri Oct 12, 2018 11:06 pm
87+ suspension will all bolt right in, just keep in mind that 87+ cars have the wider track width so you will have to keep that in mind when it comes time to get wheels.
Post  Guitmn on Sat Oct 13, 2018 5:52 am
Thanks Starkey, this parts car has decent wheels that I will use, they have a Porsche center cap but I'm not sure if they are factory wheels . Anyone seen these before?[You must be registered and logged in to see this image.]
Guitmn
