» HOW TO DO AN ADVANCED SEARCH.
Yesterday at 10:26 pm by Guitmn
» light delete badge panel.
Yesterday at 8:58 pm by x.l.r.8
» Early / late suspension
Sat Oct 13, 2018 5:52 am by Guitmn
» 944 LSD turbo/NA transaxle
Sat Oct 13, 2018 5:01 am by murrayg
» Used Throw Out bearing
Fri Oct 12, 2018 9:18 pm by Admin
» Used C5 Adapter Plate for 2 piece bellhousing
Fri Oct 12, 2018 9:08 pm by Admin
» axles and cv joints
Fri Oct 12, 2018 12:03 pm by kevin924kevin
» Holley Pro Street Annihilator Ignition system
Thu Oct 11, 2018 7:39 pm by x.l.r.8
» Fuel pump for carb.
Thu Oct 11, 2018 6:29 pm by x.l.r.8
» radiator and fan
Thu Oct 11, 2018 4:44 pm by matt889
October 2018
rover v8 bell housing
Post  x.l.r.8 on Wed Oct 10, 2018 11:53 pm
Rover v8 bell housing machined to fit 944 torque tube. uses the rover flywheel and I have a hydraulic throw out bearing mounted to the plate where it mates to the torque tube.
You could always cut the bell-housing off and use the indexed plate I have to weld your housing on for a different engine. Hydraulic bleed valve has been extended to allow bleeding from outside the bellhousing.
$500 Cad for the set up including master cylinder and line.
x.l.r.8
