» Fuel tank over pressurizing
Today at 8:13 am by JW1970
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
Hydroboost? 1/2" Spacers?
Post  AS15 on Tue Sep 11, 2018 9:49 pm
Hi guys,
Having some trouble determining which hydroboost system to use. It seems like there is a lot of talk about the mustang HB, which is what I think I am leaning towards. Trying to get a price on it but that brings me to my question; which hydroboost off of what Mustang should I be looking for? Is there a certain year/model that has the best fitment for this type of conversion (LS1 in a 1985 NA 944)?
Secondly, has anyone been able to mount an LS1 with and LS6 intake, under the hood without having any cosmetic changes to the hood, and without using the spacers to drop the crossmember? I know the spacers give you some more wiggle room with things, and I know its a tight fit between other components, not just the hood, so I'd like to know if its been done or if the spacers to drop everything is the way to go?
AS15
Re: Hydroboost? 1/2" Spacers?
Post  Arthropraxis on Wed Sep 12, 2018 8:10 am
You will have to use spacers. I got by with .25in and trimming the hood ribs. Didn't run hydroboost can't help you with that other than is seems the optimal solution is the mustang hydroboost coupled with the Porsche factory MC to keep the appropriate brake bias.
Post  murrayg on Wed Sep 12, 2018 10:43 am
Also an 85 (early) and LS1. I ran a 3/8 spacer and notched the hood. Also use an LS6 intake, no problems. I run a BMW HB which mates directly to the 944 master cylinder. I don't get the Ford / adapter solution, why not run the BMW setup? I couldn't be happier with the result.
Gord.
murrayg
Post  Rothaus on Mon Sep 17, 2018 12:19 pm
murrayg wrote:Also an 85 (early) and LS1.   I run a BMW HB which mates directly to the 944 master cylinder.  I don't get the Ford / adapter solution, why not run the BMW setup?  I couldn't be happier with the result.
Gord.
Can you post a picture from the BMW booster installation, and which BMW model.
Engelbert
Rothaus
Rothaus
Post  Hotrodz of Dallas on Mon Sep 17, 2018 1:16 pm
murrayg wrote:Also an 85 (early) and LS1.  I ran a 3/8 spacer and notched the hood.  Also use an LS6 intake, no problems.  I run a BMW HB which mates directly to the 944 master cylinder.  I don't get the Ford / adapter solution, why not run the BMW setup?  I couldn't be happier with the result.
Gord.
Probably due to the higher cost of the BMW vs the Mustang HB. Plus the extra stuff to mount and plumb on the BMW. Mustang HB is a much cleaner package overall. But that's just my 2 cents.
Hotrodz of Dallas
Hotrodz of Dallas
Post  sharkey on Mon Sep 17, 2018 2:33 pm
i also dont thing you can get everything for the bmw unit new, and they are just hard to come by. i think ive seen one car in my local junkyard with hydroboost on it. you can go to any parts store and buy the mustang hydroboost
Post  5.0L951 on Tue Sep 18, 2018 1:50 am
Another vote for the BMW system. Very simple mount with no clearance issues at the master cylinder, extra valve is a minor inconvenience. Brakes work fantastic. Found mine cheap at a local wrecker first try. Maybe just lucky but it was cheap, its been reliable and it works great.
5.0L951
Post  kevin924kevin on Tue Sep 18, 2018 12:57 pm
I purchased the bmw system. I got a brand new master unit on line. My new 944 master bolts right on/ I had to sand the male part of the 44 unit to allow a nicer install fit, It was tight to begin with. You can by the ball new, the valve unit new and the tank from what i saw and did with out a problem. If cost is an issue with a little searching you can get used. My opinion brakes get all new.
RE: Hydroboost
Post  remaxagent33 on Thu Sep 20, 2018 9:16 am
I used the Mustang HB from Sweeting Performance see link below. I have a LS6 and I am very happy I did the HB
HB Link
remaxagent33
Post  docwyte on Mon Sep 24, 2018 7:56 am
If you use the Mustang hydroboost you should also buy the adapter so you can reuse your stock 944/951 master cylinder.
One advantage to the BMW system is the 944/951 master cylinder bolts right on with no adapter needed
BMW Hydroboost
Post  spencerorme on Fri Feb 08, 2019 9:04 am
What series and year hydroboost from BMW are we to look for?
spencerorme
Post  87944turbo on Fri Feb 08, 2019 2:50 pm
Here is some good general information.  I have this system as well.  Apparently it was around for quite a while.  Mine came with all the other swap parts.  I haven't gone looking for new parts, but have heard that most if not all are still available from BMW.  I shudder to think what all these parts would cost new.
This is what my setup looks like.
87944turbo
Post  spence on Fri Feb 08, 2019 3:01 pm
Nice, you got it figured out. Did you have any issues with teeing the lines together?
Post  87944turbo on Sat Feb 09, 2019 7:14 am
Hey Spence, yeah it seems to be working fine now, no more noise at least!  Unfortunately, I still haven't had the chance to drive it yet, tracking down other issues.  But this is what I came up with.  I was able to find this stainless steel T on eBay.  It was unique in that leg has a 90 degree bend in it, which helps to keep the lines closer together.  I put the T as close to the reservoir as possible, hoping that the pressure drop to the reservoir would discourage either of the lines back feeding the other.
So far so good, but at this point it's only run at idle on jack stands.  Still way more lines, connections, and potential areas for leaks that I would like, but at least everything is where I can keep an eye on it. Thanks for your help in the other thread!
87944turbo
Post  spence on Sat Feb 09, 2019 7:24 am
Looks good. Glad you got it figured out!
