Expuppy told me of you guys, I need help.
Hey everyone, I am new to this forum. I managed to do a ls1 conversion on my first gen or 1/85 844. I order the complete kit from RH. I am living in Stillwater Oklahoma at the moment, only 20 mins from hallett race way and wouldn't mind seeing other 944s
I am having some trouble getting my gauges to work properly. I am not sure what is going on, I am most likely goign to have to run stand alones to each guage.
So first my coolant gauge sits at the halfway point when i turn the car on without running, when I turn on my headlights it goes to the black square on the left side of the gauge. It would seem I have a resistance problem or crossed wire. not sure.
On the stock oil pressure gauge there are three wire plug ins. +, G, and a T thats upside down.
I am having problems making it work right, expuppy says it might be the sender. My biggest concern with the setup is how to wire the gauge properly. I hooked to the 9 pin connector so I know how to tap into the harness.
If i need to make a stand alone for the oil system where do each of the wires plug to, I have the three prongs on the back of the guage, and I have the two on the oil sender. the wk for the "idiot" light and a G for the guage.
Has anyone bypassed the stock harness and ran their oil wires for them? If so can you assist me please?
I hope this forum is more help then Porsche hybrids. Looking forward to talking to everyone.
collin
collin
Re: Expuppy told me of you guys, I need help.
IMO trying to hook to the factory gauges is only cosmetic. I don't trust the factory gauges , When we are running cars like ours, I like to see the vitals, I only trust good quality after market gauges and if you can use manual gauges.
Just my 2 cents
Welcome aboard....
Just my 2 cents
Welcome aboard....
What are good gauges to use?
I was planning on buying a VDO coolant gauge with numbers on it so I can actually see something other than the little tick marks.
As far as the oil goes, I am not sure what to do.
Just by a nice set of VDO gauges. Any reputable name in gauges are usually good. The Vdo's are what our cars have anyway so there is a good chance the sending units will work without changing them.
That would solve alor then, Don't the gauges come with a wireing schematic too. I appreciate it. I'll probarably end up doing that.
With your guage acting the way it does it sounds like a ground problem, indicated by turning the lights on changes the reading. I would run through the chassis grounds and clean them. Alwys a decent place to start on the early cars.
944v8inDFW- Posts : 147
thanks i'll check them out
» Someone just told me I can't do an LS1 swap on an 89 2.7litre
» Tunage for EXPUPPY
» Hybrid Crests / Part D'eux...
