» Heat stuck on high
Who uses Mustang MC with Hydroboost in 944 ? EmptyYesterday at 2:11 am by Porsche951toLS3
» Selling TPC LS Swap Kit + Ceramic Headers + SPEC Clutch / Flywheel + Hydroboost + More
Who uses Mustang MC with Hydroboost in 944 ? EmptyFri Jul 19, 2019 11:42 pm by matt889
» WTB: TPC LS Swap Kit
Who uses Mustang MC with Hydroboost in 944 ? EmptyFri Jul 19, 2019 11:24 pm by Zach968
Who uses Mustang MC with Hydroboost in 944 ? EmptyWed Jul 17, 2019 10:02 pm by sharkey
» Hydroboost low pressure port
Who uses Mustang MC with Hydroboost in 944 ? EmptyWed Jul 17, 2019 3:03 pm by rdanford
» Alfa Romeo 2.5L V6 --> '78 924
Who uses Mustang MC with Hydroboost in 944 ? EmptyMon Jul 15, 2019 5:11 pm by porschekid7
» WTB: LS Swapped 944
Who uses Mustang MC with Hydroboost in 944 ? EmptyMon Jul 15, 2019 4:57 pm by porschekid7
» 1987 Porsche 944 S - Transaxle FOR SALE
Who uses Mustang MC with Hydroboost in 944 ? EmptySun Jul 14, 2019 12:55 pm by MotoRider42HC
» V8 Swap Project Car Swap Out
Who uses Mustang MC with Hydroboost in 944 ? EmptySun Jul 14, 2019 6:12 am by DirtRocket
» Transaxle rebuild
Who uses Mustang MC with Hydroboost in 944 ? EmptyFri Jul 12, 2019 8:12 pm by Jasonscottw
July 2019
Who uses Mustang MC with Hydroboost in 944 ? Empty Who uses Mustang MC with Hydroboost in 944 ?
Post  Rothaus on Thu Jul 26, 2018 12:18 pm
I'm using the Mustang MC with Hydroboost in my 944 LS1 swap. I just wondering who uses the same setup, and what's the feedback.
For me the brakes feel fine. My car is a daily driver.
Cheers
Engelbert
Rothaus
Rothaus
Who uses Mustang MC with Hydroboost in 944 ? Empty Re: Who uses Mustang MC with Hydroboost in 944 ?
Post  sharkey on Thu Jul 26, 2018 1:14 pm
i made a post in your build thread on why its not a good idea to use the mustang master cylinder.
Post  matt889 on Thu Jul 26, 2018 8:26 pm
im using stang hboost with its master and a BIAS valve ajustable one from wildwood. The fittings are close to the Exhaust headers so i wouldnt recommend track heat Smile
matt889
Post  Hotrodz of Dallas on Fri Jul 27, 2018 12:42 pm
As a daily driver you will be okay, as long as you don't have to get into a panic stop. The Mustang master cylinder is bias'd more to the rear than the 944 master cylinder. You would lock up the rear brakes in a sudden stop, which could cause a spin out. I always use the TPC adapter and mount the 944 MC.
Hotrodz of Dallas
Hotrodz of Dallas
Post  jpkinerk on Fri Jul 27, 2018 9:10 pm
So what about tracking an LS swap 944? I currently have a BMW hydroboost setup and I've set it up to work well, but I'm frustrated with the overflow of the PS reservoir. Obviously with the Mustang hydroboost that isn't an issue, but will it perform as well on the track?
jpkinerk
jpkinerk
Post  Hotrodz of Dallas on Sat Jul 28, 2018 7:40 am
jpkinerk wrote:So what about tracking an LS swap 944? I currently have a BMW hydroboost setup and I've set it up to work well, but I'm frustrated with the overflow of the PS reservoir. Obviously with the Mustang hydroboost that isn't an issue, but will it perform as well on the track?
What power steering pump are you using? Only time I had overflow was with the stock pump. Went to the turn one pump and never overflowed again. And that was on the mustang hydroboost.
Hotrodz of Dallas
Hotrodz of Dallas
Post  haroldk on Tue Jul 31, 2018 8:58 am
I use a Mustang master and a proportioning valve (can't remember for sure right now, but I believe it's a Wilwood). I autocross the car and had to turn the rear brakes down a fair amount, but haven't had any issue with the rears locking up first since the first year I had that setup.
haroldk
haroldk
Post  chrenan on Tue Jul 31, 2018 9:33 am
I track mine with a Mustang Hyrdroboost, 951 Master, Turn One Pump, fluid cooler and manual steering. That setup hasn't casued me an issue, and honestly braking feels really close to how it did before the swap.
chrenan
Post  962porsche on Sat Sep 08, 2018 9:19 am
personally i hated it.
i did one track event and they totally sucked they worked OK but just OK in the street.
the next day after my 1st track event i ordered a dual master peddle assembly with in car brake bias adjuster.
i use the rennbay front calipers kit with both setups and they work far better with the dual master setup too.
i think i spent about 700$ for the wilwood hydroboost and it was a total waste of my money.
even if i spent half that for me it would be a waste of money i hated it that much.
just one of the things i didn't like was the big differences between lower speed braking and high speed braking. i couldn't ever get it do do both and be happy doing it. the peddle feel was also nothing great it was ok but sure in hell not good for tracking the car.
braking systems is not one place to compromise on even for street uses.
962porsche
962porsche
