Hydroboost, have to pull pedal..?
Page 1 of 1 • Share •
Hello! I have an LS swapped 951, I’m running the mustang Hydroboost setup from TPC, everything works good, just noticed a small issue. It seems after I push down the pedal and release the pedal looks like it comes up all the way, but can still feel the car is still braking some so I checked and after I pull the pedal with my hand it comes up about 1/4”-1/2” and it’s back to normal. I have to pull the pedal up the little 1/4”-1/2” (which is max the pedal can come up) every time I Brake. Any idea what this might be?
C4924S- Posts : 47
Re: Hydroboost, have to pull pedal..?
if it still braking it the pedal ajustment. happened to me
matt889- Posts : 183
matt889 wrote:if it still braking it the pedal ajustment. happened to me
Which adjustment to be exact?
C4924S- Posts : 47
the pedal clevis on the brake pedal at the top under the dash !
matt889 wrote:the pedal clevis on the brake pedal at the top under the dash !
Do you know if I need to make it shorter or longer?
C4924S- Posts : 47
Pedal issues
Could it be on a bad angle? Is it binding?
Also, could it be that you have the clevis to tight? It needs to be able to articulate fully.
Also it could still have air in the system if it’s not returning fully. Jack the front of the car up and re bleed the system. Possibly brake lines too.
zeusrotty- Posts : 434
like i said mine was leaving the brakes on slightly and i had to ajuste it so i wouldnt
» Pull - Pull Control Cables
» how do i make a gas pedal ?
» 34 Bumper pull or 38 goose neck help !
» 2010 PUMA Unleashed Toy hauler (Bumper pull)
» How to Build a Pull Start!
» LS Conversion Kit Plus
» SBC Pilot Bearing
» 924 Twin Turbo 5.3 C5 T56 swap!!
» Lighten clutch pedal feel?
» WTB: Brake Caliper Adapters
» LSA Supercharged 86 Porsche 944
» lS1 CONVERSION COOLING QUESTIONS
» Looking for : Torque tube Core
» Hydroboost? 1/2" Spacers?
