New here needing help
New here and need some help. I'm wanting to put a 200R4 transmission in . I'm having a hard time finding info on automatic installation. Do I need to cut and modify the tunnel? Also I've heard about installing a mustang rear end and 4 linking it . Any and all help would be appreciated
Woodys944- Posts : 2
Re: New here needing help
yes you will need to cut the tunnel, you will also have to eliminate the factory heater/ac box as the trans and tunnel need the space where the heater sits. as far as a 4 link and solid axle, again, itll all be custom.
not too many people go solid axle and eliminate the torque tube, its sort of counterproductive to what the car is supposed to be.
Ok cool . just trying to come up with a solution to my problem . I have the automatic car which is my issue lol. So would i be better off by putting in the turbo transmission? Or looking for the c5 vette torque tube and set up?
your best bet would be the turbo 5 speed and torque tube. the vette transaxle and torque tube takes a lot of fabrication to make work.
Today at 12:47 am by sharkey
