» Fuel tank over pressurizing
Today at 8:13 am by JW1970
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
Tight Clearance Exhaust Manifold for Turbo build
Post  Mongo on Tue Apr 10, 2018 12:30 pm
I've decided to turbo my 5.3, and shove the turbocharger behind, and below the passenger headlight. From what I have read, clearances are tight to reverse factory cast iron truck manifolds to plumb the hotside.
Texas Performance headers appear to conform to the engine better but no idea on how they sit when reversed. Hooker Headers makes turbo manifolds too but the collector appears to stick out too far. They are also $$$$.
Any recommendations on a good set of turbo headers for this LS build?
Mongo
Re: Tight Clearance Exhaust Manifold for Turbo build
Post  yamamtx on Sat Jun 02, 2018 12:23 pm
I ended up building my own out of the LS manifold. I flipped them so they faced forward and then cut and welded from there. Things are very tight so it takes a lot of work but it can be done.
yamamtx
Post  Jchard944 on Wed Jun 06, 2018 8:08 am
Check these out. I don’t have my motor installed yet but these are hard to beat if they fit. They do provide nice measurements/dimensions so you could see if they would work. You can actually buy them individually and even with crossover to connect the two.
https://www.holley.com/products/ls_power/ls_exhaust/ls_exhaust_manifolds/parts/8510HKR
Jchard944
Post  matt889 on Thu Jun 07, 2018 6:57 pm
does look like stock truck manifolds they dont cut it with the steering Shaft !
matt889
Post  Mongo on Mon Jan 14, 2019 11:09 pm
The TPC header for the driver side will work with the Hooker passenger. I can duct the driver side around to the passenger for the merge from the rear of the engine.
Unfortunately a while back I got scammed out of a deposit on a 944 and the build is on hold
Mongo
Post  Jchard944 on Tue Jan 29, 2019 6:29 am
Mongo, Did you fit the hooker manifold on the passenger side? Curious if you mocked all of this into a car to confirm.
Justin
Jchard944
Post  Mongo on Wed Jan 30, 2019 6:30 pm
No not yet (see my post above). Need to shop for another car and buy the header.
Mongo
