Tachometer Issues
Tachometer Issues
I am struggling to get my tachometer to work with my LS3. I have swapped to a late interior in my car, and I believe everything is wired properly. I ran a new wire for the tach signal and have it wired directly into the instrument panel connector 2. I tested this wire, and the 12V input for the Tach with an aftermarket unit, and it reads just fine. But the Porsche tach will not budge. I am using a 1k ohm resistor as a 12V pull-up resistor. What has everyone else done for wiring the tach? Is this resistor too large?
Thanks!
Thanks!
superman22x- Posts : 272
Re: Tachometer Issues
has the tach output been turned on in the ecm? some cars run the tach signal through the data bus and as a result the tach output isnt enabled and needs to be turned on with a tuning program.
sharkey- Posts : 713
Yeah, I did double check that, good there.
I put in a different resistor (480ohm) between the 12V pin and signal pin on the back of the tach, and it worked now... I guess it just needs a stronger signal. The GM performance parts instructions just recommend a 5,000 Ohm resistor. Oh well, I think it is good now... The other two Porsche tachs I had must have actually been bad. Guess the Porsche tachs are a little sensitive?
I used the Dakota Digital signal converter. Simple and accurate. The cost is small, in the grand scheme of things.
948 wrote:I used the Dakota Digital signal converter. Simple and accurate. The cost is small, in the grand scheme of things.
Both the LS and Porsche use a 4 cylinder signal, I guess I'm not sure what the Dakota signal converter does other than add 12V pullup to the LS signal.
LOL, don't mind me. I have an LT1, totally forgot that the LS is a 4 cylinder pluse. LT is an 8 cylinder pluse.
superman22x wrote:948 wrote:I used the Dakota Digital signal converter. Simple and accurate. The cost is small, in the grand scheme of things.
Hey Superman22x, for the 480 ohm resistor you used, how many watts was it?
Ordie792002- Posts : 3
1/4 watt. The typical tiny resistors you get in a kit.
Today at 9:56 am by ndog52
