944s 1987 clutch not disengaging
Page 1 of 1 • Share •
We have bleed the lines and have a hard pedal, but the clutch will not disengage. Looking to upgrade the Clutch Master cylinder. I have read the Tilton 75 serious ( not sure what size bore 13/16 or 7/8 etc. Or the Wilwood 260-10373 13/16 or the Wilwood 260-10374 7/8 bore.
Are any an option and will they direct bolt up or modification needed?
remaxagent33- Posts : 9
Re: 944s 1987 clutch not disengaging
Mine is a 13/16. The mounting holes have to be elongated and the threaded rod has to be cut down. I am not aware of any MC that does not require some minor modification.
Arthropraxis- Posts : 1091
which MC brand / model # did you use
» ecotec swap
» Tachometer Issues
» 83' Porsche 944 LM7 Build
» Corvette C6 Z06 Brake Caliper Adapters
» Hydroboost problems
» WTB: 944 Turbo Roller
