» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
This Hydroboost system is going to drive me nuts
Post  Red944ls1 on Mon Mar 12, 2018 7:54 pm
I figured I'd take the car out this weekend cuz I was back in town.  My power steering system is driving me crazy.  Initially I thought it was the GM pump that was causing the issue.  I changed out for a Cadillac CTS-V pump as it gave more pressure then the GM pump.  It worked fine for probably about 5 minutes. I'm assuming as the fluid heated up it stopped working.  I have no idea what the problem is I'm thinking the air is getting into the system and therefore causing it no longer to work when I let the car sit overnight and start it after it has been sitting it works fine for the first 5 minutes or so.
Any thoughts?
Red944ls1
Re: This Hydroboost system is going to drive me nuts
Post  sharkey on Mon Mar 12, 2018 9:04 pm
the power steering reservoir where it is, and the long hose is going to cause you a ton of issues. power steering pumps dont like to suck fluid, they need to be gravity fed. the long hose with multiple bends is likely not keeping the pump fed, and as soon as that happens the pump cavitates and starts making noise.
the first thing id do is figure out a fluid reservoir as close to the pump as possible. im thinking something like a gto reservoir. you will have to add the extra return fitting for the hydroboost to that one, could use a self sealing bulkhead fitting, or get an aluminum version and have an extra nipple welded on.
Post  P911P951 on Tue Mar 13, 2018 6:57 am
Using ATF right?
Jack
P911P951
Post  Red944ls1 on Tue Mar 13, 2018 10:46 pm
Yes..atf...before I switched to the CTS-V pump I was using CHF.
I still don't get why it works perfectly fine until the car has been running for about 5 minutes.
Red944ls1
