Audi 1.8 Builds
Audi 1.8 Builds
Recently I got turned on to the Audi 1.8 conversion. Why? well a couple of reasons, first the availability of the engine, aftermarket support, and the HP they make. Second is the weight savings - wow! HP and less weight = fast. If you think yea right, well look at this thread:
So my question is who has done one? Which conversion parts did you use, meaning which engine code, bell housing, flywheel, clutch, mounts and ECU where used? I would assume some of the Audi parts are re-purposes, but how? I did see this post from a person in the UK, but what about here in the US?
And please, I am not debating "why" to do it, just who has, what was the process, parts, and concerns etc, maybe some links to help us lost souls.
cazbah362- Posts : 17
Re: Audi 1.8 Builds
im not sure anyone on here has done any audi swap. there has been talk on here about various vw/audi engines, but i dont think its gone past that. i have seen a couple searching on google.
you are right on the weight thing though, my swap (2.2l ecotec) weights around 300 lbs fully dressed. i havent had a chance to scale the car yet, but i figure it should be around 50 lbs lighter on the nose. now these cars already have a 49% front 51% rear weight bias, so if your looking to build a car that handles exceptional, care needs to be taken to keep the weight balance in check.
Re: Audi 1.8 Builds
There have been several 1.8t swaps done. First I recall was about 7 years ago.
