» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
Return spring
Return spring
Post  kevin924kevin on Mon Jan 29, 2018 3:42 pm
Could some one post a picture showing how the return spring works/mounts. As my car was a cable clutch in its old life. Thanks in advance. I ordered a spring moded my new pedal just need a pic or two.
Re: Return spring
Post  haroldk on Mon Jan 29, 2018 4:50 pm
Are you talking about the spring on the clutch pedal? If so, it's an assist spring. I had to remove mine because it would stick the pedal to the floor unless I had it backed all the way off.
haroldk
Re: Return spring
Post  kevin924kevin on Tue Jan 30, 2018 1:47 pm
i am am talking about the return spring on the clutch pedal.
Re: Return spring
Post  haroldk on Tue Jan 30, 2018 1:53 pm
Yeah, that's not a return spring, it's an assist spring. I wouldn't worry about it unless your clutch is really hard to actuate.
haroldk
Re: Return spring
Post  kevin924kevin on Tue Jan 30, 2018 4:01 pm
Ok perfect. Thank you for the info.
Re: Return spring
Post  sharkey on Tue Jan 30, 2018 10:12 pm
yea the overcenter spring on the clutch pedal most of the time gets eliminated. the way they are designed is at the top of the travel the spring is pushing the pedal back up, but once it gets past center on its pivot it puts force down on the pedal to make the clutch feel softer. the problem is once you start messing with the clutch setup in any way they usually dont work that well. often times a performance clutch is designed in a way that gives a lighter pedal but more holding power, and what happens is the over center spring is too stiff and the clutch pedal sticks to the floor, or it comes part way up. most of the time people just eliminate it, it gives a more "raw" clutch feel.
Re: Return spring
Post  kevin924kevin on Wed Jan 31, 2018 7:13 am
Thanks again for the good insite, should have done this before i ordered one.
Re: Return spring
