Vented Nose Panel  EmptyYesterday at 2:55 pm by Porsche951toLS3
» Intake Piping For Very Tight Clearances?
Vented Nose Panel  EmptyYesterday at 2:46 pm by MotoRider42HC
» WTB: LS Swapped 944
Vented Nose Panel  EmptyYesterday at 1:16 pm by porschekid7
» tips on removing headers?
Vented Nose Panel  EmptySun Jun 23, 2019 8:57 pm by Worryless
» Lighten clutch pedal feel?
Vented Nose Panel  EmptySun Jun 23, 2019 8:44 pm by Worryless
» Torque Tube Heat - What is Normal?
Vented Nose Panel  EmptyWed Jun 19, 2019 12:14 pm by superman22x
» FOR SALE: Kokeln Dual Master Bracket
Vented Nose Panel  EmptyWed Jun 19, 2019 12:13 pm by MotoRider42HC
» Replacement Radiator
Vented Nose Panel  EmptyWed Jun 19, 2019 11:20 am by Hotrodz of Dallas
» ISO ls swap done with working AC :)
Vented Nose Panel  EmptyWed Jun 19, 2019 8:19 am by stilov
» 1987 Porsche 944 S - Transaxle FOR SALE
Vented Nose Panel  EmptyFri Jun 14, 2019 7:04 pm by MotoRider42HC
June 2019
3456789
10111213141516
17181920212223
24252627282930
Vented Nose Panel
Vented Nose Panel  Empty Vented Nose Panel
Post  Red944ls1 on Wed Jan 17, 2018 1:34 pm
Does anyone have one or know where I can get one?
(Vented nose panel / header panel
Red944ls1
Vented Nose Panel  Empty Re: Vented Nose Panel
Post  sharkey on Wed Jan 17, 2018 2:54 pm
gt racing makes one, so does ifc parts. ive also seen a seller on ebay that makes them.
just keep in mind the 944 n/a and 944 turbo and s2 use a different nose panel, so make sure the one you get is for the nose your car has.
Post  Hotrodz of Dallas on Wed Jan 17, 2018 4:00 pm
Red944ls1 wrote:Does anyone have one or know where I can get one?
I have one that came off of a clients car that he no longer needs. I will check and see what he wants for it.
Hotrodz of Dallas
Hotrodz of Dallas
Post  Red944ls1 on Mon Jan 07, 2019 7:28 pm
I ended up making my own.  Took the old one off and cut it up and fiberglasses it.  Turned out pretty good.  Didn't cost me anything as I had the fiberglass and bondo
.[You must be registered and logged in to see this image.]
Red944ls1
