Power and Torque figures
Hi
I recently had my car tested on a rolling road. The figures are as follows:
Engine power - 285 bhp or 212Kw, Wheel power 222bhp or 166Kw and Torque - 214lb.ft
Max power at 132mph.
Bearing in mind that the engine is from a '95 vette do the figures seem about right?
I think the power might be in the right region but the torque seems low.
Thankx
Q
Thankx
Q
Re: Power and Torque figures
is it an lt1 or lt4? the lt1 is factory rated at 300hp and 330 ft/lb, so the horsepower figure is right in the ballpark for a 22 year old engine, but the torque number seems wack.
Yes it is an LT1 and I agree the torque seems too low. Also the engine has only done just over 62,000 miles.
Thanx
Q
Thanx
Q
Using a 15% loss at the rear wheels as compared to the crank/engine numbers your HP and torque numbers sound a bit low. 222HP divided by .85 = 261(at the engine). Use the same math for the torque.
Your results sound low.
Fubar- Posts : 9
Today at 6:58 am by Rob44
Today at 12:47 am by sharkey
