Selling my 1986 Porsche 951 LS1 :(
$15,000
This is a sad day for me, but it’s finally time to get rid of my long time “fun” car and move onto new projects and chapters of life. I’m hoping that this car can find a home where it will bring as many smiles to the new owner as it did to me.
All the modification details are below. In 2010 I installed a second generation LS1 V8 from a 2004 Pontiac GTO. I’ve been driving the car regularly in the summers, and have put on approximately 20k on the swap with very few issues. I’ve recently had it on a track once and it was an absolute blast, other than that I’ve used it for autocross off and on. I’ve never been a very skilled driver, but I’m sure with the right person behind the wheel it could be a monster. The car is in the neighborhood of 3000 lb, and has 340 WHEEL horsepower (measured), making it quite quick. I’ve also gone through the whole suspension in order to bring the rest of the car up to speed with the additional power.
I bought the original car in 2009 with 84k on it and in rough shape, the engine swap and extensive suspension work has brought the car back into its performance prime. Please see below for all the goodies. Everyone has different tastes when it comes to modifying a car, and whoever the buyer is I’m sure you will make the car your own, but what I can say is that this swap has been installed for long enough and has had enough miles put on it to be sure that the bugs have been worked out. My good friend and I recently drove the car from Boston to Madison WI and back with plenty of side trips along the way (~1,800 miles) and a track day in the middle, the car was fine the whole time. I’ve never driven the car in the snow, and the whole car is rust free.
I’m asking $15,000 and would ask that only serious buyers inquire, just send me a PM and I’ll get back to you in the evening after work. For more information I've made a public Facebook page for the car that you can find a link to below. I am in the Boston/Northeast area. I believe that is an excellent price for a car that has this much power, and has been shaken down this thoroughly. These cars are a pleasure to work on and a pleasure to drive.
No car is perfect, and in the interest of transparency I want to make the buyer aware of certain issues: The paint is not perfect (see photos), the dash is cracked (like so many other 944’s out there), there's a tiny bit of curb rash on one wheel, I have not installed AC (the evaporator is still in the dash, so it could be installed without too much trouble), the odometer is not currently working, and like many German cars not all the interior electronics are perfectly functional. The radio, windows, wipers, lights, and mirrors all work fine though. Additionally, while I find this a major advantage and a fun aspect of the car, some people may find the manual steering, brakes, and clutch to be too heavy for their taste. Be warned that this is a visceral car to drive and demands serious respect when behind the wheel.
This was the original forum that helped me with the conversion, you can still find my build thread on here, but unfortunately Photobucket singlehandedly messed that all up, and I'm not paying them $33 bucks a month for their image hosting...
I've made a Facebook page with lots of information:
Here is some additional information and pictures for those of you without Facebook:
Stock Car Information
Engine
Intake/Exhaust
Additional Gauges/Interior
Cooling System
Drive Train
Transaxle
Front Wheels/Tires
Rear Wheels/Tires:
Suspension
Other parts available
Other notes
Alignment
Steering
Brakes
Here are some addition images:
- Year: 1986
- Model: 944 Turbo (951)
- Options: M030 suspension
- Color: Garnet Red Metallic (LM3Y)
- VIN: WP0AA0955GN155558
- Early offset (23.3mm) 16” phone dials (7” and 8” width) on front/rear axles with early offset front
- aluminum control arms
- Stock Rear Tire Setup: 225/50R16 (24.9 dia)
- Stock Front Tire Setup: 205/55R16 (24.9” dia)
Engine
- Year: 2004
- Donor Car: Pontiac GTO
- Original Millage: 81,000
- Designation: LS1
- Displacement: 5.7L
- Factory HP (crank): 350
- Factory Torque (crank): 365 ft-lbf
- Max RWHP (measured): 340
- Max RW torque (measured): 340 ft-lbf
- Plug Wires: Taylor
- Engine Mounts: Poly
- Bell Housing: C5 Corvette 2 piece
- Oil Pan: Moroso 20140
- Oil: 5W-30 Royal Purple synthetic
- Oil capacity: 7.5 qts
- Remote oil filter mount
- Oil cooler
- NAPA 1515 oil filter, Royal Purple 30-8A
- Water pump and alternator only, 6 Rib, ~55 ¼” belt
Intake/Exhaust
- Renegade hybrids headers, 1.75in primaries, 3in collectors, ceramic coated
- Single 3.5in to Vibrant Performance 17970 resonator, then to a 3.5in MagnaFlow 12909 muffler
- Two 3in SS flex sections after headers before Y pipe
- Corvette K&N FIPK intake (P/N 633073) customized to fit in front of radiator
- AEM wide band with Bosch sensor
- New pioneer head unit
Cooling System
- Radiator: Griffin 1-26201-X Aluminum Pro Series Radiators, 24inx16inx3in, 2 rows
Drive Train
- Clutch/flywheel
- Clutch: Spec Stage 2
- Clutch Master Cylinder: Tilton 75-875U .875” bore, 1.1” stroke with custom braced firewall mount
- Clutch lines: -3AN SS braided
- Flywheel: Spec Aluminum, 13lbm
Transaxle
- Transaxle: Stock Audi with 944 NA 5th gear swap
- Transaxle mount: Lindsey racing semi-rigid bushing
- Transaxle reinforcement plate
- Differential: OS Giken superlock LSD
- Transaxle oil: 75W-90 Royal Purple MaxGear
- Oil capacity: 2.7 qts
- Short shift kit from only944.com, I’ve added additional bronze bushings to remove slop from the kit
- Custom shifter with wooden knob
Front Wheels/Tires
- 275/40R17 Nitto NT555 G2 (25.7” dia)
- ZR1 17”x9.5”, 56mm offset, 5x120.65 bolt pattern
- 5x120.65 bolt pattern
- .984” 21mm spacers from Motorsport Tech with a 5x130mm to 5x120.65mm bolt pattern conversion
- Final effective offset with adapters/spacers on ZR1 rims: 35mm, decreasing scrub radius from stock by 11.7 mm and decreasing wheel centerline track width by 23.4 mm from stock
Rear Wheels/Tires:
- 315/35R17 Nitto NT555 G2 (25.7” dia)
- ZR1 17”x11”, 50mm offset, 5x120.65 bolt pattern
- .630”, 16mm spacer (driver side) and .669”, 17mm spacers (passenger side) from Motorsport Tech with a 5x130mm to 5x120.65mm bolt pattern conversion
- Final effective offset with adapters/spacers on ZR1 rims: 34mm (Drivers), 33mm (Passenger) decreasing centerline track width by 20.4 mm
- A set of 15 mm spacers and a set of 25 mm spacers come with the car (leftovers from previous fitment checks)
Suspension
- Rear Springs: 600 lb/in Eibach (PN: 0600.250.0600) with 250-650 progressive tender springs (PN: 0200.250.250-550)
- Front Springs: 600 lb/in Eibach (PN: 0600.250.0600) with 250-650 progressive tender springs (PN: 0200.250.250-550)
- Front Dampers: KONI Yellow inserts (single adjustable), ground control coilover conversion kit
- Rear Dampers: KONI Yellow (single adjustable), ground control rear coilover conversion kit
- spring plates bushings: Delrin
- Rear swing arm bushings: Elephant racing monoball
- Front control arm bushing: Elephant racing monoball
- Front control arm caster block: Elephant racing monoball
- Ground control front caster and camber plates (top mount style)
- 19 mm ball joint conversion from paragon products
- Front strut tower brace
- Torsion bars 29mm, 295.98lb/in at wheels, Swayaway
- 440lb/in Eibach springs (2x)
Other notes
- The progressive rate springs should probably be upgraded to 0200.250.250-650 in order to have more tender spring travel before the main spring takes over
Alignment
- Front Caster: 4°
- Front Camber: -2°
- Front Toe: +0.11°
- Rear Camber: -1.25°
- Rear Toe: -0.1°
Steering
- Elephant racing bump steer kit
- 924 manual rack modified to work with late inner ball joints/tie rods, 21” from inside face to inside face of inner ball joints
Brakes
- Master Cylinder: Wilwood 260-7563 1” Bore, 1.1” Stroke tandem manual master cylinder with custom braced firewall mount
- Bias Valve: Wilwood 260-10922 manual adjustment brake bias valve
- Lines: -3AN braided SS at master cylinder with 944Online braided SS lines at the calipers, hard lines between
- Pads: PBR Ultimates
Luke714- Posts : 441
Re: Selling my 1986 Porsche 951 LS1 :(
Nice list of modifications. What all would need to be done to hook up the AC? Just adapter lines from the GM to Porsche?
4lo- Posts : 8
Hi, thanks! I don't want to lead you wrong and tell you it would be a quick job. The evaporator is still there, as are the connections to it, but you would still have to install the compressor and condenser. Being in Maine I never was able to check this one off my list.
Car is snowed in at the moment, but still available!
Looks like some fantastic work.
I do not have facebook. Could I email you offline? I do not have full PM access yet.
Vincent Joyce- Posts : 4
PM sent, thanks for the interest!
Hello,
I've had time to clean the car up for the spring and do the regular maintenance so I've started advertising it again for the spring! Currently using it as my daily driver, and having a ton of fun Posted on craigslist now, but you can also send me a PM.
[You must be registered and logged in to see this link.] (https://maine.craigslist.org/cto/d/1986-porsche-951-with-ls1-swap/6614660617.html)
There's also lots of information on the car's Facebook page, where you can also contact me. [You must be registered and logged in to see this link.] (https://www.facebook.com/1986Porsche951LS1Conversion)
Cheers,
Luke
Cheers,
Luke
saw it on LS1 tech.
GLWTS
GLWTS
carr911- Posts : 24
Hello all,
The car is SOLD. Thank you all for being such great support during the build 8 years ago! I plan to keep the Facebook page I made for the car active so that other swappers can look. There's a complete ledger with all the parts listed: [You must be registered and logged in to see this link.]
Best,
Luke
Best,
Luke
» Selling my running 1986 944
» WTB: LSX (V8) Swapped 1986 944 Porsche
» FS: 1986 Porsche 944 Turbo 350 LT1 turn-key
Today at 9:56 am by ndog52
