1983 944 Front Passenger A-arm
Hello there everyone
I have a 83 944 with passenger side lower a-arm issues. I bought a bushing kit but have decided to just to swap out the entire a-arm.
Can you recommend where to buy one new with everything ready to bolt on the car?
Ed
Ed
mred2nice- Posts : 79
Re: 1983 944 Front Passenger A-arm
rock auto has them listed, $60 each with the balljoint. they are made by dorman products
I to have an 1983 944 and I just purchased all new front control arms and polyurethane bushings. I will provide part #'s and prices below. Everything I got is brand new and appears to be really nice quality. Hope this helps. Total both sides together cost me just over $100 before shipping. Figure it was worth ordering in pieces since I was able to throw in some polyurethane bushings instead of stock OEM's.
Following was ordered from Pelican Parts:
Controls Arms (Front Left Outer, Front Right Outer)
Brand: Lemfoerder Part#: 944-347-333-01-M253
Price: $22/each (Need 2)
Link: [You must be registered and logged in to see this link.]
Ball Joint for Control Arm (Front Left or Right)
Brand: Delphi Part#: 171-407-365-G-M292
Price: $10.50/Each (Need 2)
Weltmeister Front Control Arm Bushing Set for Front of Steel A-Arm, PB-1019, Set of 4, 924/944 (1976-1/85) (1983 Porsche 944 Base Coupe)
Part#: PEL-PP911939
Price: $12.99/Each (Only Need 1 for front end for both left and right)
Items bought off Ebay:
Ricochet Polyurethane Bushings: Fits Prosche Front Control Arm Bushing Pair 924 944 1976-1/85 Polyurethane New
Price $24 (Only need 1 as it contains both left and right)
Part#: PEL-PP911939
Jchard944- Posts : 96
Thanks for your responses. They have been really helpful.
Would you chance know where I can get a steering shaft? Mine is pretty sloppy.
Ed
Ed
paragon-products.com has the power steering shaft, the manual steering shaft was discontinued by porsche and no longer available, so if you have a manual rack your going to have to track down a good used one.
