» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
Pontiac GTO LS1
Pontiac GTO LS1
Post  panteraTT on Sat Nov 04, 2017 4:31 pm
Does anyone know of any issues with using a Pontiac GTO LS1 engine for the 944 swap? Are there any modifications or part swaps necessary to use this engine?
panteraTT
Re: Pontiac GTO LS1
Post  Arthropraxis on Sun Nov 05, 2017 5:48 pm
I have one. The only issues were the AC compressor has to be swapped for a F-body unit, remove the rear alternator brace to clear the motor mount and the ECU has to be programmed to turn on Hi/Low speed fans. I forget right now but one of the fans is controlled by the Body Control Module. The ECU has to be programmed anyhow to remove the security feature.
