Rear seat delete
944Hybrids: 924/944/968 and 928 V8 Conversions :: Technical Stuff (other than motors) :: Interior upgrades
Rear seat delete
Just wanted to post up a few pictures of my latest project and get some feed back.
To go from this dried up cracked useless rear seat to a smooth flat rear set delete setup .
Just about ten minutes of work and the old seat was out and ready for the new fiberglass insert to be fitted
Then a quick test fit, sorry about the blurry picture.
This was designed to set on top of the existing carpet and insulation. Just a couple of screws and its ready for carpet. The carpet will be let long on some of the edges so that it can be tucked under the factory carpet and side panels. I will post pictures of finished carpet job as soon as I get the carpet in.
Re: Rear seat delete
Good idea! What will something like that cost?
zeusrotty- Posts : 444
Not sure just yet, I'm still working on getting the mold for it cleaned up, then we will do a run and see how much time and materials it will take. I will offer it in two versions, a race version and a street version. The race will be relatively thin and light, the street version may have a thin wood veneer imbedded in it to make it more durable and able to hold speakers if so desired.
Rear Seat Delete
Has the decision been made to not bring this product to market?
Powerman951- Posts : 22
Planning something similar on my 944 project but with a sheet of 6061 aluminum and two subs mounted
Awinski- Posts : 1
