Oil Cooler Adapter Not Working?   EmptyMon Apr 15, 2024 7:28 pm by JW1970
Oil Cooler Adapter Not Working?   EmptyMon Apr 15, 2024 6:59 pm by JW1970
Oil Cooler Adapter Not Working?   EmptyMon Apr 15, 2024 9:51 am by Raymond-P
Oil Cooler Adapter Not Working?   EmptyFri Apr 12, 2024 3:07 pm by Rob44
Oil Cooler Adapter Not Working?   EmptyWed Apr 10, 2024 10:09 pm by LS982
Oil Cooler Adapter Not Working?   EmptyTue Apr 09, 2024 8:45 am by gwistrup
Oil Cooler Adapter Not Working?   EmptyTue Apr 09, 2024 1:54 am by lowform
» WANTED: 948 Conversion Manual
Oil Cooler Adapter Not Working?   EmptyMon Apr 08, 2024 1:52 pm by Elskeptico
» FS 1989 Transmission for 944
Oil Cooler Adapter Not Working?   EmptyTue Apr 02, 2024 10:02 am by 87roadracer
Oil Cooler Adapter Not Working?   EmptyTue Apr 02, 2024 6:00 am by 89EFhatch
Oil Cooler Adapter Not Working?   Empty Oil Cooler Adapter Not Working?
Post  jpkinerk Wed Oct 11, 2017 8:22 pm
I recently installed an oil cooler adapter from Improved Racing (LS low profile), got the oil up to temp and the actual cooler is still...cold. Temp sensor is showing 240 degrees and I still have good oil pressure, so I'm guessing the thermostat in the adapter is bad? I just can't believe I'd have bad enough luck to get a new part with a failed thermostat. I REALLY don't want to take that all apart again, very tight in there.
Anything I could be missing?
jpkinerk
jpkinerk
Oil Cooler Adapter Not Working?   Empty Re: Oil Cooler Adapter Not Working?
Post  sharkey Wed Oct 11, 2017 9:32 pm
might be helpful to share more about your setup. what oil pan do you have? are you running a remote oil filter?
