Today at 12:20 pm by superman22x
» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Random High Idle
Random High Idle
Post  fantic on Mon Oct 02, 2017 7:48 am
I have started to have a high idle problem. When starting the car cold it revs to 2000 rpm. It will stay there even when it is warm. I can unplug the iac and the tps and do the reset and it will start and idle at around 650. The next day same thing. It's like the computer has lost it's memory overnite. What do think is going on?
fantic
Re: Random High Idle
Post  gdopnt on Mon Oct 02, 2017 6:10 pm
Do you have a code light on? The IAC is the cheapest thing to replace and the first thing to change. The cable type blade wont raise the idle unless you do it one way or the other. You should have a code light on if you unplugged those two pieces.
gdopnt
Post  fantic on Tue Oct 03, 2017 12:23 pm
I replaced the iac last week. No change. I think I may have found my problem. The tps is 2.7% when cold. When hot it is 0% at idle. I can reset it to 0 and its good till the next morning. Then it is back to 2.7%. Going to try a new tps.
fantic
Post  gdopnt on Tue Oct 03, 2017 8:23 pm
2.7% is very precise, do you have software?
gdopnt
Post  fantic on Tue Oct 03, 2017 8:36 pm
That what my Snap On scanner shows me. Replaced the tps and seems to fix the problem. Know more in a couple of days. Now I have a P0327 knock sensor 1. Always something.
fantic
