Steering rack clearance
1987 944s LS6
Trying to fit Power steering rack on the car, hitting oil pan Any suggestions
944s LS6- Posts : 13
Re: Steering rack clearance
Is the torque tube attached to the engine and transaxle to the torque tube?
who made the oil pan? a manual rack has a little more clearance
remaxagent33 wrote:1987 944s LS6
What oil pan are you using? Sometimes the steel lines on the rack have to be tweeked a little to clear the pan. Otherwise, depending on what pan you are using, it should clear the rack itself.
Steering Rack Clearnce
I had a company here local remake the lines reusing the porsche fittings
» Steering rack clearance
» Steering Rack Question
Today at 6:58 am by Rob44
Today at 12:47 am by sharkey
