» FS: LS1 Swapped 1985.5 944
Headers, headers, HEADERS! - Page 8 EmptyToday at 5:24 pm by turbobob924
» Need Advice - My Helmet Hits The Roll Cage
Headers, headers, HEADERS! - Page 8 EmptyToday at 5:03 pm by Hotrodz of Dallas
» 86 Porsche 944T LS1 swap begins
Headers, headers, HEADERS! - Page 8 EmptyToday at 1:15 pm by smkn951
Headers, headers, HEADERS! - Page 8 EmptyYesterday at 10:17 am by smkn951
» HELP!!!! Need a little help with final wiring connections....
Headers, headers, HEADERS! - Page 8 EmptySat Sep 14, 2019 6:29 pm by Midevil1981
Headers, headers, HEADERS! - Page 8 EmptySat Sep 14, 2019 11:39 am by Rothaus
» WTB 928 LS Swapped, Auto Trans. Also advice needed
Headers, headers, HEADERS! - Page 8 EmptyTue Sep 10, 2019 7:20 pm by Saintanky
» FS: TPC Motor Mounts
Headers, headers, HEADERS! - Page 8 EmptyTue Sep 10, 2019 10:53 am by Jchard944
» Early Tach not working with LS3?
Headers, headers, HEADERS! - Page 8 EmptyMon Sep 09, 2019 8:13 pm by superman22x
» 85.5 944 LS Adventure
Headers, headers, HEADERS! - Page 8 EmptyMon Sep 09, 2019 4:07 pm by departeg
September 2019
30
Page 8 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8
Headers, headers, HEADERS! - Page 8 Empty Re: Headers, headers, HEADERS!
Post  Hotrodz of Dallas on Sat Aug 06, 2016 8:51 am
240Z2NV wrote:Despite the fact that there's a CARB # on their Listing .....
Those headers you listed do have carb #'s. But as soon as you modify one to work in the 944, it will no longer be carb compliant. No one makes a carb compliant header for the 944 LS swap.
Hotrodz of Dallas
Hotrodz of Dallas
Post  LStuner on Wed Jun 27, 2018 12:53 pm
Has anyone mocked up aftermarket C6 Vette Longtubes? They appear to hug the block nicely and come together just after the Bellhousing.
LStuner
Post  osx86ftw on Thu Jun 28, 2018 8:07 am
I used the PaceSetter 70-2259 headers for a G8 on mine, ~$250 for a set makes them budget. Had to cut and weld both sides, and a little bit of hammering for the starter on the passenger side. For the passenger side, I just cut a slit on the top of all primaries, then I could bend them inwards to clear the frame rails and the A arm mount. For the driver's side, I had to slit the primaries again (to clear the same things), and modify #3 and #5 primaries to clear the steering shaft. For both, I had to move the O2 sensor bung to the side of the collector, as well as slit the top of the collector to bring it down some to better clear the floor. Lots of work, but much cheaper than any other option for long tubes... Very Happy I can get pics if anybody wants.
osx86ftw
Post  docwyte on Thu Jun 28, 2018 8:27 am
Nothing off the shelf fits without a bunch of modification. Period.
So decide how much your time is worth to you, than either buy the direct fit headers TPC, Renegade or Kooks sells, or buy something else and spend time modifying it to fit.
Post  LStuner on Thu Jun 28, 2018 12:00 pm
osx86ftw wrote:I used the PaceSetter 70-2259 headers for a G8 on mine, ~$250 for a set makes them budget. Had to cut and weld both sides, and a little bit of hammering for the starter on the passenger side. For the passenger side, I just cut a slit on the top of all primaries, then I could bend them inwards to clear the frame rails and the A arm mount. For the driver's side, I had to slit the primaries again (to clear the same things), and modify #3 and #5 primaries to clear the steering shaft. For both, I had to move the O2 sensor bung to the side of the collector, as well as slit the top of the collector to bring it down some to better clear the floor. Lots of work, but much cheaper than any other option for long tubes... Very Happy I can get pics if anybody wants.
If you wouldn't mind getting a few pics of these that would be awesome!
LStuner
Post  osx86ftw on Mon Jul 02, 2018 3:31 pm
I'll see if I can get some decent pics, they're installed now and it's hot as $#** out, I'll see if I can get some on the 4th (my car sits about 30 minutes away from home)
osx86ftw
Post  osx86ftw on Sat Jul 07, 2018 6:26 pm
Driver's side shot:
Passenger's side shot:
Rear view of the headers, you can see where I relocated the oxygen sensor bungs, the exits point straight back, which isn't ideal, but workable I think (haven't made a y pipe yet) Also did 3 inch to 2.5 inch reducers on them.
osx86ftw
Post  osx86ftw on Sat Jul 07, 2018 6:32 pm
My remote oil lines BARELY clear, I used 150 degree 10AN fittings here, with a pan from Summit
Where I mounted my oil filter (I may move it farther down as I don't believe it will clear the stock overflow tank
Clearance around the starter, I could have done a little less hammering, probably. I would recommend a starter blanket
osx86ftw
Post  osx86ftw on Sat Jul 07, 2018 6:36 pm
Clearance by the washers for the A Arm mounts is close, but not terrible
Sorry for the bad pictures, but they're installed and I didn't take any pictures beforehand, you can see the weld seams, which gives you an idea of how I went about piecing it together, I honestly don't remember what angles I used, I think I had salvaged them off of a previous set of these headers I had failed modifying. The piece that curves towards the block I had to massage a bit with a hammer to clear the steering shaft, works nicely now.
osx86ftw
Post  LStuner on Sun Jul 08, 2018 4:44 am
osx86ftw wrote:Clearance by the washers for the A Arm mounts is close, but not terrible
These help me alot, Thank you for taking the time to capture and upload! I am fairly confident that the Aftermarket C6 Longtubes will be a good starting point. Will report back once i get the process going Very Happy
LStuner
Post  osx86ftw on Sun Jul 08, 2018 3:39 pm
I think that's a good idea, looking at how they're shaped I'd choose those if I were to do it over again
osx86ftw
Post  z06801 on Thu Jul 12, 2018 11:15 am
are the Kooks still avalable?
z06801
Post  Hotrodz of Dallas on Fri Jul 13, 2018 10:17 am
z06801 wrote:are the Kooks still avalable?
Kent at TPC has the kooks for sale
Hotrodz of Dallas
Hotrodz of Dallas
Post  Slow Motion on Sat Aug 24, 2019 10:58 am
The only Specifically designed Long Tube 1-7/8 LS Swap Headers offered for 924 944 951 968 chassis are still available for immediate shipping for MAP price of $1,995 which includes free ground shipping to the lower 48 US states. These were CAD designed and mandrel bent for perfect flow and no restrictions. Measurements were 3D scanned to use every available square inch for the most engine efficiency and offer plenty of clearance when using either TPC, Renegade, or copied similar engine mounts. I have these private label through Kooks and am the only distributor for these. If you contact
Kook's to purchase, they will refer you to me, Slow Motion Speed Shop 336-448-3881
These can be ordered though TPC or direct from me as needed for immediate shipment via Fed Ex.
Yes these are expensive and they are not for everyone's budget so if you would like a cheaper header please choose a different style/brand, make a custom set, or modify the hooker style. the But, if you want true performance, ask those who have spent the extra and purchased these from myself or Kent and you will be more than satisfied with the results my headers produce.
Thanks to all of those who have supported in purchasing my headers in the past and those who continue to support and follow us in our adventures in the #PoorVette.
Follow us on IG at [You must be registered and logged in to see this link.]
Slow Motion
Slow Motion
https://www.instagram.com/slowmotionspeed/
