» What dipstick??
Yesterday at 2:46 pm by chrenan
Yesterday at 10:25 am by superman22x
» Hello, Gentlemen.
» WTB: 944 Turbo Roller
Mon Jun 18, 2018 11:38 am by chrenan
June 2018
Alternator Hook up
Alternator Hook up
Post  Red944ls1 on Mon Jul 10, 2017 11:49 pm
Hi all...I have looked at a few post and still am a little confused.
I have a Silverado alternator with a two wire hookup with a harness connect done by SSP.
I understood that I simply connect the two pin weatherstripping connector and then the blue wire from the original Porsche connection and I would be fine. The battery is not charging with this hookup. The voltage inside on the dash is reading but again not charging. Do I need to hook 12v to the back of the alternator to the battery as well?
Thx
Red944ls1
Re: Alternator Hook up
Post  sharkey on Tue Jul 11, 2017 12:28 am
the blue wire is hooked to the field circuit of the alternator, this is what essentially turns the alternator on. you also need a battery cable hooked from the back of the alternator to the battery, this is the output from the alternator to charge the battery. this should be an 8 gauge wire or larger.
Post  Red944ls1 on Tue Jul 11, 2017 12:47 am
Thanks for your quick response. Currently I have the blue wire to the back of the alternator and the plug from the harness attached to the alternator. If the 8gauge wire is to go to the back where to I hook up the blue wire...not to sound ridiculous :-)
Red944ls1
Post  sharkey on Tue Jul 11, 2017 1:19 am
im not sure what alternator you have exactly, but here is a general diagram that should point you in the right direction
with a 2 pin you should have the L and S on it, wire them up as shown. S goes to the alternator stud, L will go to the blue wire in the car. you then run an 8 gauge wire from the stud on the alternator to the battery
Post  Red944ls1 on Tue Jul 11, 2017 4:24 pm
Thanks for the drawing.  My two wire connector connects the two in the middle and the wires are red and brown whereas the drawing connect the second and 4th. Any ideas..
Red944ls1
Post  spence on Tue Jul 11, 2017 5:29 pm
follow the drawing and you should be fine
Post  Rich L. on Thu Jul 13, 2017 9:55 pm
Here's the setup I used with my Camaro alternator and the pigtail from Painless.
Post  Red944ls1 on Sun Jul 16, 2017 9:04 am
Thanks for the replies. The alternator is up and running. I rant the 8 gauge wire from the back of the alternator to the battery. I connected the blue wire to the L wire by splice and then connected the pigtail from the harness the alternator.
It is charging now.
Red944ls1
