» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
AeroCatch pin mounting
Post  rdanford on Wed May 24, 2017 4:23 pm
Going to be removing the stock hood latch to reroute air filter to under the front nose panel and want to use the AeroCatch latches...Where and how are you all mounting the pins?
Thanks!
rdanford
Re: AeroCatch pin mounting
Post  dsrracer on Wed May 24, 2017 8:02 pm
I used aluminum angles which are clipped into the vertical leg.
dsrracer
Post  dsrracer on Wed May 24, 2017 8:06 pm
dsrracer
Post  rdanford on Thu May 25, 2017 10:16 am
So how are you securing the mounts? Thanks for the pics!
rdanford
Post  dsrracer on Sat May 27, 2017 2:06 pm
The pens are visible. The vertical legs of the angles are the outboard legs and those legs are sheer clipped him to the bulkhead with two 3/16 fasteners. The horizontal leg of the angle also has two 3/16 fasteners so that the forward nose section that covers the filter will install flush. This provides fairly rigid installation for the pins even cantilevered as far as they are. The reason they're cantilevered so far back is so that the catch will not penetrate the forward cross beam of the hood. Take some more pictures so that you can see the sheer clips but everything's covered now for painting. I should have everything stripped back by mid week if more pictures would help let me know.
dsrracer
Post  rdanford on Sat May 27, 2017 11:33 pm
Thanks for the details, yes any additional pictures and advise would be great!
rdanford
Post  dsrracer on Tue May 30, 2017 2:44 pm
Do theses help?
dsrracer
Post  rdanford on Tue May 30, 2017 5:11 pm
Yes, that's great...thanks!
rdanford
