Franken44 Part Out - fresh motor and all conversion parts
It's a little like putting your pet down, but it's time - parting the Franken44:
Two weekends in new motor - LS3 crate motor with LS1 heads and LS6 intake. Small road racing cam. Makes 440 RWHP, 420 TQ with monster torque curve. Just broken in, and esssentially all new - not a junkyard motor. Comp Cams trunion upgrade, and springs. Comp cams restricted pushrods. AN-12 ports in valance covers for a breather. Intake manifold is flipped, but this is reversible. TPC baffled/trap door oil pan. $6,000 for the entire motor/pan. This is drop in ready for a 944.
All new GM performance ECU, Drive by wire pedal (modified for linkage from separate gas pedal), and all new wiring harness for a plug and play swap. This has been a dream vs the junkyard swap I fought with for a while. Reliable, easy, and great drivability. 480 HP tune, which worked well, but has been further dyno optimized. $850
TPC ceramic coated shorty headers with Burns stainless merge collector into 4" oval pipe. V-band connectors. $900 for all.
QuickTime SFI rated bellhousing. Bulletproof and the adaptor is built in - meant for LS to 944 swap. I broke my aluminum Corvette bellhousing with my old LS1, so I upgraded - nice unit! $500.
Solid motor mounts- TPC $150
Aluminum fly wheel, and aluminum 4 puck clutch. Light - revs fast! Semi streetable, but a dream on the race car. Super fast shifts vs A steel clutch. 6 weekends in this. $700 for the clutch and flywheel.
AOR trans with an external Mocal cooler connected to the OEM geared pump via AN lines. $1,750 for trans and cooler.
JRZ triple adjustable, remote reservoir shocks. 3 seasons on rear rebuild, and one on front shock rebuild. Several springs from 750 to 1,000 lbs per inch. $1,750 for shocks, and $200 for 3 pairs of springs. Upper spring perches have thrust bearings
Racers Edge camber plates $200.
2 sets of 18 x10 wheels Enkei NT03 +M $900 per set.
1 set of square 17x9" OEM Cup 2 wheels $700.
Large Mishmotoo oil cooler. $100
Solid trans mount - $100
3 Quart Accusump with electric solenoid, check valve, and AN-10 connections. 2 weekends old. $300
Oil cooler thermostat for AN10 $75
Remote oil filter with huge Wix Racing Oil filter and 5 filters ($20+each for each filter)
$175 with the filters
Wilwood 6 piston calipers. These are axial mount with 3/8 plate steel adaptors for 944 S2 hubs and VW Touareg rotors. $400.
60k mile 944 S2 ABS front spindles (bought as spares and not used) $200
Tilton on triple pedal setup for manual brakes with master cylinders, and remotely adjustable brake bias via balance bar- works great - $650
Rear OEM turbo calipers $200
Predator high mount fiberglass rear wing with uprights. $400
Lexan rear hatch $300 (pick up only)
Traqmate data acquition with Replay camera. $400
Rear torsion tube with Elephant Racing Polybronze bushings, and spherical bearings on the banana arms $500
5 liter AFF fire suppression system $175
Weltmeister antisway bars front and rear. The front has a home built mounting system, and would need new drop links built (simple heir joints and threaded rod would work) $500 for both bars
Sabelt Halo seat. Still in FIA certification (I will check for how long soon) $450 with side mount brackets
Momo steering wheel dished, leather, with quick release and 944 adaptor. $275 for all.
AIM brake pressure sensor, oil pressure sender, and oil or water temp sendors. $50 for each
Steering angle sensor -belt driven, never installed -$75
String pot throttle position sensor for AIM (used) - $50.
AIM patch cable - will include with 1st couple of sensors bought
Large Autometer Comp tach- $90
Various electrical and mechanical temp gauges $25 each (minimum 3 to ship)
Will make package deals.
Sterling Doc- Posts : 113
Re: Franken44 Part Out - fresh motor and all conversion parts
Interested in Solid Motor Mounts and Camber Plates! Thanks.
Will Send PM.
Will Send PM.
944_GASM- Posts : 68
Interested in the steering wheel, quick release and adaptor. I will send you a PM. Thanks
Jchard944- Posts : 96
The transmission, shocks, entire brake setup, fire system, transponder, and seat are sold.
Is the solid transmission mount one of XSchops? I may be very interested in it, I have a late 85 model with AGR trans.
GarethW- Posts : 26
It's a Lindsey Racing unit. It is meant for the late top center mount. If your car is an oval dash car, it will fit.
motor mounts still available?
5pntlow- Posts : 1
All that is left now is the rear suspension with the elephant racing polybronze bearings, and spherical bearings on the banana arms, and the Painless wiring harness.
