» Dual MC Mounting Bracket
Yesterday at 10:02 pm by 948
» LS1 1st start
» Need help! Car won’t start
» Brand new ls3 build
» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
FS: SPEC Stage 3 Clutch Disc
Post  944_GASM on Wed May 03, 2017 9:27 am
As the title states, I have a SPEC Stage 3 Clutch Disc. Just purchased the set off another member, but will not be running a Stage 3 setup, but rather a Stage 1.
Was used for less than 10 hours on the track and after visual inspection, I couldn't see any wear whatsoever.
Looking to get $100 or B/O. Open to Trades plus cash on my end if necessary for other swap parts (Motor Mounts, Pilot Bearing adapter, Throw out bearing, etc.)
Not selling the Pressure plate or flywheel.
944_GASM
Re: FS: SPEC Stage 3 Clutch Disc
Post  spoon4364 on Mon Jun 05, 2017 10:09 pm
I cant send a PM, due to low post count. If available ill take it. Does it include the flywheel as well? Thank you.
spoon4364
Post  944_GASM on Tue Jun 06, 2017 7:09 am
spoon4364 wrote:I cant send a PM, due to low post count. If available ill take it. Does it include the flywheel as well? Thank you.
Item just recently sold.
Earl
944_GASM
