Yesterday at 8:00 pm by Luke714
Yesterday at 12:23 pm by chrenan
» What dipstick??
Sat Jun 23, 2018 4:54 pm by chrenan
Sat Jun 23, 2018 8:28 am by rawr
Fri Jun 22, 2018 10:25 am by superman22x
» Hello, Gentlemen.
» WTB: 944 Turbo Roller
June 2018
Can I change S2 5th gear??
Post  murrayg on Tue Apr 25, 2017 1:51 am
Hi all,
I'm using a S2 box because thats what I had. While it's a blast around town, it is not very nice on the highway. This less than optimal gearing is well known and well discussed on the boards. I've searched and been to Clarks Garage, and I'm confused. Can I replace the 5th gear set to help here. I understand the real problem is the FDR, bet would another 5th gear set help. And which one???
Thanks.
Gord.
murrayg
Re: Can I change S2 5th gear??
Post  Rich L. on Tue Apr 25, 2017 11:21 am
Sure you can. Your AOS/AOT box has a 0.77 5th gear set. The long 5th from the 5S box is 0.72 and the short 5th people want to ditch from the AOR is 0.82. So going to the long 5th would lower your revs at the same speed in 5th gear but only about half as much as it does the turbo boxes.
Post  murrayg on Tue Apr 25, 2017 2:25 pm
Thanks Rich,
I have the QM box that was in the car (early 85). That also has the .72 gearset. Can I use it in the AOS? If it's easy to do, I'll go ahead, even if the benefit is marginal. Cost is nothing!
Gord.
murrayg
Post  sharkey on Tue Apr 25, 2017 3:39 pm
yea that gearset will work just fine. its not too hard to do, but you either gotta pull the trans out, or cut the hole in the spare tire well.
Post  Rich L. on Tue Apr 25, 2017 3:55 pm
Cool Gord. I've not done it but there's a good write-up in the wiki. That .77 gear set is the one I want, care to sell/trade? What I have the .82 in my AOR.
http://944hybrids.pbworks.com/w/page/23371592/944%20Transaxle%205th%20Gear%20Swap
Post  murrayg on Tue Apr 25, 2017 11:49 pm
Hi Rich,
Sorry, but this won't be happening anytime soon! I'm 6000 kms away from the car until the end of the summer. I'm just building a list of things to do when I return.
ciao,
Gord.
murrayg
Post  Rich L. on Wed Apr 26, 2017 10:49 am
Copy. No hurry here either as the car is up and running for track season. When you get them out, ping me on here. Thanks.
