» FiTech option
Thu Sep 20, 2018 2:06 pm by sharkey
» Hydroboost? 1/2" Spacers?
Thu Sep 20, 2018 9:16 am by remaxagent33
» Drag set up
Tue Sep 18, 2018 5:47 pm by Ij944
» FS ABS Powerbrake system pressure pumps
Tue Sep 18, 2018 1:09 pm by jpr
Tue Sep 18, 2018 10:43 am by Rothaus
Tue Sep 18, 2018 10:13 am by Ij944
» 82 924 with AUX Audi V8.
Tue Sep 18, 2018 3:17 am by Golten1986
» Clutch Issues - HELP!!!
Mon Sep 17, 2018 11:16 am by chrenan
Mon Sep 17, 2018 10:08 am by chrenan
» Brand new ls3 build
Sun Sep 16, 2018 7:46 pm by Plucky948
September 2018
3456789
10111213141516
17181920212223
24252627282930
944 BH Pattern
944 BH Pattern
Post  TurboCarrera on Tue Apr 11, 2017 5:38 pm
Has anybody accurately measured the 944 pattern? Looking to make an adapter plate because the engine I want to use doesn't have any detachable bellhousings, but I'm struggling with an accurate way to measure the 944 pattern.
I already have a clutch flywheel, and know my adapter thickness, etc. The first plate I made was off by a tiny amount for crank to input shaft concentricity.
Any insight would be appreciated.
TurboCarrera
Re: 944 BH Pattern
Post  sharkey on Tue Apr 11, 2017 9:04 pm
what engine are you using? when i did my ecotec swap i was able to find a bellhousing intended for a an ecotec mated to a t56, and i made a very simple adapter from t56 to the torque tube.
Re: 944 BH Pattern
Post  TurboCarrera on Wed Apr 12, 2017 5:21 pm
The engine is a mazda 2.5 v6. Never meant for longitudinal mounting. I have that pattern is CAD already, and for my first adapter plate. For the 944 side, I put a 944 bellhousing on my mill and used a coaxial indicator to find the centre of all the holes. The bolt holes and dowel locations were good, but it turns out they didnt care too much about the clutch guide tube hole as it was ~1.5mm off crank centre line.
TurboCarrera
Re: 944 BH Pattern
