Intake Air Temp
Intake Air Temp
I have been fighting a high idle. 1500 rpm. I noticed my IAT is 170 deg no matter cold or hot. I just bought a new Delfi 5 wire MAF. IS that is where the IAT comes from? I wouldn't think 170 would cause a high idle but just checking.
fantic- Posts : 48
Re: Intake Air Temp
if you have a 5wire Maf it has the iat inside of the sensor so yes it's there what does ur intake setup look like? And that is really high idle so you have vacuum leaks? Or IAC valve wired right? Sounds like ur Maf isn't plugged infantic wrote:I have been fighting a high idle. 1500 rpm. I noticed my IAT is 170 deg no matter cold or hot. I just bought a new Delfi 5 wire MAF. IS that is where the IAT comes from? I wouldn't think 170 would cause a high idle but just checking.
matt889- Posts : 214
Re: Intake Air Temp
I called PSI the company that made the harness. We found the harness was wired wrong. Sometime in 2014 the color codes were changed. Runs good now.
fantic- Posts : 48
